RE: GAS Saito
Tower Hobbies
Logged in as Guest
Users viewing this topic: kiosk, Ed Vollmer, Olli-Matti, Hans Meij, bhorton
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: GAS Saito
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: GAS Saito - 10/24/2007 9:32:49 PM
DLEVETT
Status: offline
The way I,m reading the specs, is that the engine itself is 48oz, the muffler is 3oz. Thats 51oz, if you add a 4oz igniton your at 55oz, which equates to 3.4lbs.
Not bad for a 4 stroke. Every 4 stroke is going to weigh more than a 2 stroke.
In the right application [airframe] this engine will be a neat alternative to whats already available.
As for the price its made in Japan so its going to cost a lttle more.
I,d still like to try one though when they get released.
Dave
< Message edited by DLEVETT -- 10/25/2007 1:50:12 AM >
(in reply to kochj)
       Post #: 51
RE: GAS Saito - 10/25/2007 1:15:49 AM
Tsutomu Mabuchi
Status: offline
I have ordered FG-36 for Don Smith Ki-61 Hien(Tony) 85".
The street price in Japan is JY75,000(US$650) , so I think $650 in US is not bad
in comparison of view.
Tsutomu Mabuchi
(in reply to DLEVETT)
       Post #: 52
RE: GAS Saito - 10/25/2007 1:52:20 AM
DLEVETT
Status: offline
Now thats going to be a good airframe to hang it on.
I should sound really good as well when compared to a 2 stroke engine.
Dave
< Message edited by DLEVETT -- 10/27/2007 3:52:51 PM >
(in reply to Tsutomu Mabuchi)
       Post #: 53
RE: GAS Saito - 10/27/2007 3:50:09 AM
Pete Bergstrom
Status: offline
Dave,
You are right about the specs. The 66oz figure includes the aluminum mount that comes with the engine. We found that it did a good job as a heat sink so we decided to include it with each engine. It is a beautiful piece all by itself.
Pete Bergstrom
Category Manager - Hangar 9/Saito/Evolution
Horizon Hobby Inc.
       Post #: 54
RE: GAS Saito - 11/1/2007 2:49:27 AM
Campgems
Status: offline
Does anyone know what size the plug is. From the photos, it looks like a 1/4-32 thread like the glow plugs. Is this the size, or is it larger?
Don
(in reply to Pete Bergstrom)
       Post #: 55
RE: GAS Saito - 11/1/2007 11:48:52 AM
Don M.
Status: online
Pete, can you tell me why they decided NOT to put bearings on the connecting rod. I'm no engineer but a plain rod running 30:1 oil mix makes me nervous.
_____________________________
I can only please 2 people every day and #2 just left.
       Post #: 56
RE: GAS Saito - 11/2/2007 2:49:46 AM
XJet
Status: offline
I suspect there are no bearings on the big-end of the con-rod because there just wasn't room. If they've used the FA220 crankcase castings then they'd have to significantly reduce the diameter of the crank-pin to fit bearings in there and that create a whole lot of other problems.
For what it's worth, we run 12% oil down this way on even our fastest-revving model engines and have *never* had a lubrication-related failure.
We do however, stick with very high quality ester-based synthetics with a hint of castor in order to do this.
The extra lubricity of these oils plus the inherently higher lubricity of gasoline could well be enough to allow such a setup.
Remember also that 4-strokes have a somewhat different lube system to 2-strokes.
It's been my experience that pretty much regardless of the amount of oil in your fuel, an equilibrium gets set up in the crankcase so that you always end up with a pool of oil that accumulates to a certain degreee and then the excess starts blowing out the crankcase breather.
So long as you start with some oil in there, you'll never run it dry, even with small amounts of oil in the fuel. Using extra oil only results in more coming out the breather.
Whenever I take the backplate off my 4-strokes there's always a good half teaspoon of slippery oil sitting in there -- whether I run 20% or 12% oil in my fuel.
When I'm not here, I'm at RCModelReviews
(in reply to Don M.)
       Post #: 57
RE: GAS Saito - 11/8/2007 2:18:20 AM
Flight Risk
Status: offline
quote:
ORIGINAL: XJet
SNIP
Good point Xjet. The bottom end of a 4-stroke is not exposed to direct fuel. The lubrication all comes from blow-by. A certain amont of oil will accumulate no matter the oil content. It seems the major limiting factor would be the heat of gas vs. glow. It would probably be fine if a good synthetic oil was used, which would stand up to high heat. I wonder if castor can be mixed with gas?
Rod S
On a Wing and a Prayer...........and a tank of Nitro...
(in reply to XJet)
       Post #: 58
RE: GAS Saito - 11/8/2007 2:24:57 AM
XJet
Status: offline
quote:
ORIGINAL: Flight Risk
Yes, you can mix castor with gasoline and it's still used quite frequently in racing circles (gokarts, etc).
However, at the higher temperatures found in gas engines it does tend to form varnish more readily than when used in glow-fuel, but that's not an issue if you're in competition racing and tear your engine down after every meet (or two).
However, for a model gas engine you might find that you end up gumming your ring after a relatively short period of time.
A good synthetic would be a good way to go -- perhaps with just a sniff of castor to help the camshaft/lifter area.
(in reply to Flight Risk)
       Post #: 59
RE: GAS Saito - 11/10/2007 6:50:42 AM
kochj
Status: offline
A great airframe for this engine would be the Gp giant aeromaster!
it is also on sale at Towers for 250$ now that is a good deal!
I got mine and it is fantastic..... Perfect everything!
Winning isn''''t everything, it''''s all there is.
(in reply to XJet)
       Post #: 60
RE: GAS Saito - 11/11/2007 12:03:12 AM
kochj
Status: offline
Chief aircraft has the engine (you can place it in your cart online), but how are you able to tell if they have it in stock or not??
Nov11 is what I heard!
(in reply to kochj)
       Post #: 61
RE: GAS Saito - 11/11/2007 10:38:27 AM
BAS
Status: offline
What do you guys think of this motor on the hangar nine extra 260 27% i think it would be a good combo.
Bruce A Swartfager
(in reply to kochj)
       Post #: 62
RE: GAS Saito - 11/11/2007 2:31:35 PM
closetguy
Status: offline
quote:
ORIGINAL: BAS
BAS, just my experience with the 220 glow.i get 8000 on a biela 20-8 prop and 7700 with a pt models 19-8. it's on a chip hyde tunnel vision at 12-3/4 lbs. has unlimited vertical,but ask it to pull that plane out of a hover and it STRUGGLES to do it. the numbers that i get are what most others are getting with there's.so i don't think there is something wrong with the engine,it's has great compresion. just no power or maybe the 12-3/4 plane is too much for it?
so most converted glow to gas engines will have a little less power than the glow version.
and at 3.4 lbs. it's heavy for this class of engines,there are 50cc engines that weigh less.
so i think it's over weight
over price
and will be under power
i may be wrong but this is my experience with the 220 glow. but it would make a nice sounding war bird engine in gas.
ENJOY!
(in reply to BAS)
       Post #: 63
RE: GAS Saito - 11/11/2007 2:35:31 PM
BAS
Status: offline
Yes the weight is a issue with me also. I dont know if your seen the video of the gas saito being flown in a 84 inch span edge but it was pretty awesome. I just love the idea a 4 stroke gasser but like you say it is pretty heavy. All up weight with the included motor mount and all components is allmost 4 lbs. I think the wing loading might be a little high for the extra. I would like to hear from Mike from Horizon on this issue. Thanks for the reply.
Bruce A Swartfager
(in reply to closetguy)
       Post #: 64
RE: GAS Saito - 11/11/2007 4:55:14 PM
kochj
Status: offline
Mike already talked about it on a nother forum!!
Justin
(in reply to BAS)
       Post #: 65
RE: GAS Saito - 11/11/2007 7:18:34 PM
