pettit
Joined: 12/19/2001 From: Durham, NC, USA Status: offline
Hot off the press: Saito FG36 tests: Total weight (engine, mount, ignition, prop nut and washer) 61.5 oz. (after 30 minutes run time) APC 20-8 7100 RPM APC 18-8 7450 RPM Idle at 1500 RPM or less 90db(a) at 25' at full RPM Hand starts easily, but I couldn't get the carb to prime by hand (no manual choke) Use electric starter first start of the day, then hand start from there on out Ignition draws about 340 ma at full speed (no huge battery needed) And it sounds GREAT!!!
_____________________________
Dick Pettit Associate Editor, R/C REPORT Magazine "You Can Buy Better, But You Can't Pay More"
