kochj
MN, USA Status: offline
My exprerience with piper cubs and floats, is that the most power that you can shoehorn in the airframe, the better off you will be!.... Floats on planes add lots of weight. I do lots of Winter flying with mine and wish I had a gas engine in the airframe because of the fits a Glow engine can give you.... But the added weight of a gas engine in this plane may be too much.... Get gas, and go for the bigger engine.... If not the saito, Look at the ZDZ 40 F3A.... Same weight at the 26cc evolution gas engine with double power.... I have so many planes right now I not sure where to start. If I do get this engine, I will stop looking at it as a Conversion Glow 220 and see it as it is..... A 30cc gas 4-stroke engine.... That is my take on the matter.... Will I get burned? not sure,, Time will tell.. I always find personall experience to be the best lesson.... Justin
_____________________________
Winning isn''t everything, it''s all there is.
