duckedup
OR, USA Status: offline
I'll let the Savage guys chime in on what you might need/want for extra hop-ups.. With the XSS kit, you're basically getting a hopped up truck already though.. you might need/want to get a 5 cell rechargable receiver pack though, not sure.... As for the radio.. -Futaba........(3PM, 3PK..) -JR..............(XS3, XR3..) -Airtronics....(MX-3, M-11..) -Spektrum....(DX2, DX3..) -Nomadio ^^ all good brands.. Since you've got decent budget, make sure you get at least a FM system. Synthesized is one FM option (no need for crystals, change the channel on radio/receiver if/when needed), FM with crystals (non synth) is the other FM option, you're just stuck on the same channel and have change the crystals to change channels.. DSM is the next step up (Spektrum), killer range, no glitching, no interference.. Spektrum has it's own complete radio system (example: DX3) but you can also get a Spektrum module for all the above mentioned brands (except the Nomadio, it has a different system).. A radio like the JR XS3 synthesized FM is a great system for the $$, that's what I run and I love it so far.. You can find it for around or under $100 on ebay and that's hard to beat considering all it's features and being synth.. If you go that route, you'll probably want to get a nice servo separately, look for a servo with metal gears and with at least 180oz of torque.. (Airtronics, JR, Futaba, KO, etc.. all make servos) The other system I like is the Spektrum DX3, I've already mentioned it's features though so I won't waste anymore space.. .. that one will cost quite a bit more though.. (I'm not sure how powerful the servos are that come with that system) Here's a couple links.. -JR XS3 ... this is just an example, you can find them for less.. -JR XS3 Pro ... basically the same as the above radio, it's got 10 model memory instead of 6 and it's silver.. might have other extra features, not sure though.. -Spektrum DX3 ... another example, this is a good price though.. Servo.. Airtronics 94358Z, 200oz. .. *just an example.. there are others for a little less but that's a good one, just make sure it's around or over a 180oz and metal geared..
< Message edited by duckedup -- 11/30/2006 12:28:10 AM >
