toddzhere2
CA, USA Status: offline
I had the Xtreme CNC blade grips with the eflite aluminum swash plate, upper and lower rotor heads, and the Xtreme hard blades on my CS for some time. Love the fact that I haven't broken any blades in a month and the heli fly’s perfectly. However, I have recently removed the CNC grips and replaced them with the Dynam Vortex plastic grips to reduce the rotating weight. Big difference in how quickly the motors spoon up now. Unfortunately, the larger ball size for the linkage on the lower rotor forces me to use the Dynam linkage between the lower blade grips and the swash plate, Therefore, I must use the Dylan Vortex plastic lower rotor head as well because of the way the linkage is held by the lower rotor heads. Any ideas as to what heli uses the larger style linkage ball on the blade grip and uses the elite style lower rotor head?
