RE: Blade CX-2
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Blade CX-2
Page: <<   < prev  98 99 100 101 102 [103] 104 105 106 107   next >   >>
Login
RE: Blade CX-2 - 2/28/2008 9:57:30 PM
mjs3350
Status: offline
rc screwz sells a kit, it's like 27$ though
(in reply to BryFlyGuy67)
       Post #: 2551
RE: Blade CX-2 - 2/28/2008 10:36:37 PM
Coyote64
Status: offline
I buy the hardware kit available from eflite that has all the screws used in it, well worth the £5 price tag $10
Its part number : EFLH1225
_____________________________
At the time of this message i have enough spare parts to build three cx`2......... by this time tomorrow ill have none.....
(in reply to mjs3350)
       Post #: 2552
RE: Blade CX-2 - 3/2/2008 7:51:29 PM
Tall Paul
Status: offline
Things to do with your Blade CX and CX-2 receivers..
Bad idea!
The ESCs in the CX 4-in-1s can't handle the main motor load!
Bad smells come out!
< Message edited by Tall Paul -- 3/11/2008 4:39:58 AM >
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to Coyote64)
       Post #: 2553
RE: Blade CX-2 - 3/3/2008 11:21:37 PM
Pilotwoody
Status: offline
Hi
The CX2 also comes with the aluminum upper head, the CX does not. Not sure if anyone mentioned that.
If you get the CX2, I would buy the aluminum lower head and have it on hand for when you break that.
It was the first thing I broke, tipped her over and actually broke the lower head and didn't break any blades..go figure?
But don't replace it until you break it, its a bit of a job.
(in reply to tinchao)
       Post #: 2554
RE: Blade CX-2 - 3/5/2008 1:57:15 AM
chris1379
Status: offline
quote:
ORIGINAL: toddzhere2
However, when I want aggressive forward flight, they both fly a bit sideways and to the left. It looks like they both lean down and to the left when I apply forward elevator. However, I can get them to fly perfectly straight and level with the nose pointing straight if I also apply a little aileron to the right.
Took me a while to get to it but if you have a DX7 you can program 2 mixes to make it fly straight. I think it will work when setup in ACRO mode as per the Horizon website but I have mine setup as a HELI with 1 servo to get the throttle curves.
[PROG MIX1]
AILE>ELEV ON
RATE: +45%
+45%
[PROG MIX2]
ELEV>AILE ON
RATE: -45%
-45%
(in reply to toddzhere2)
       Post #: 2555
RE: Blade CX-2 - 3/5/2008 8:13:35 AM
Coyote64
Status: offline
quote:
ORIGINAL: Pilotwoody
Hi
I broke three lower heads, the plastic shafts for rotors to attach to is far too weak, as you said my blades would not snap the head did, so i swappeed it for alu one and no more lhs visits for that !
I did swashplate as well because my big bear claws kept breaking the plastic balls off it, again i swapped with no regrets
(in reply to Pilotwoody)
       Post #: 2556
RE: Blade CX-2 - 3/5/2008 10:16:26 AM
TomcatDriver
Status: offline
sorry to ask this guys,..... as it may have been covered,..but my CX2 pirouettes soooo much faster to the right, and takes around 4-5 seconds for just one to the left,....is this normal?,... I have just got my 3 in 1 replaced,..and all my trim pots and gain are set correctly,.... being co axial, should this not be equal in both directions???
JJ
       Post #: 2557
RE: Blade CX-2 - 3/5/2008 1:35:34 PM
BryFlyGuy67
Status: offline
quote:
ORIGINAL: TomcatDriver
JJ
This is completely normal and is just a flight characteristic of the CX/CX2.
Flying may not be all plain sailing, but the fun of it is worth the price. -Amelia Earhart
2 CX2s, Walkera 4, TREX SE V
(in reply to TomcatDriver)
       Post #: 2558
RE: Blade CX-2 - 3/6/2008 9:20:45 PM
notjaykay
Status: offline
After 2 days and 1 set of blades later, I finally got through this entire thread. Ugh, what a read.
Count me in with the very happy CX2 owners club. Only thing I've upgraded is the swash and lower rotor assembly with the aluminum stuff. Only broke one set of blades after about 8 flights by crashing it into myself...whoops.
Picked it up from http://www.hobbyhangarva.com/ which is only a 10 minute drive from where I live. They stock the entire E-Flite catalog which is awesome. Good for me, bad for my wallet.
I'm probably going to pick up a carbon fiber tail with a blue canopy, and an upgraded inner and outer shaft, and a new flybar later tonight.
       Post #: 2559
RE: Blade CX-2 - 3/11/2008 4:30:06 AM
UTM
Status: offline
Just finish up reading every single post in this thread.
Found great info here and I thank all of you for putting it out there to find.
I am in in the camp of mod it if it makes you happy and do so liberaly with my Cx2. I've put on Alum lower head, swash, and upper bearing cup. I also have shortened my flybar, moved my servo linkages to 3rd hole on elev. and 2nd on aler, and installed the Xtreme 180bb motors (the best money spent on this heli). I recently purchased a CF tail boom and am having a problem.
I find that the fit of the mounting plate is a little loose around the servo mount which allows the boom to vibrate or rattle a little. Any tips for a snugger fit?
Thanks again for all of the great info. I've only been flying helis for about 3 months and feel like I have progressed much quicker due the the great advice here. Keep it coming
Rules are made for people who aren''''t willing to make up their own....Chuck Yeager
(in reply to notjaykay)
       Post #: 2560
RE: Blade CX-2 - 4/14/2008 10:12:03 PM
ppike
Status: offline
Not sure if anyone has mentioned it in this thread or any other on the CX, but we have found that you should use the same mold number on the upper or lower blades. Seems to be enough difference between blade molds to throw off things a bit. I am talking about the small mold ring on the inner top of each blade half. Has a mold ring with number inscribed in it. If your blades are a #3 they should both be #3 on the top. The bottoms can be say a #2 but they both should be the same across from each other. Does not make any difference as far as being the same upper and lower just side to side. They also seem to have put the number outside this mold ring on some blades. We have been able to correct many flight issues with making sure the blades are the same.. Hope this helps.
(in reply to runover1)
       Post #: 2561
RE: Blade CX-2 - 4/15/2008 5:24:55 AM
chris1379
Status: offline
You are right, both blades in a pair should have the same number. Also, if you have tail spin you can''t adjust out, try changing either set of blades to ones from a different mold.
Chris
(in reply to ppike)
       Post #: 2562
RE: Blade CX-2 - 4/15/2008 1:58:01 PM
Crusader23
Status: offline
