RE: Blade CX-2
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Blade CX-2
Page: <<   < prev  98 99 100 101 102 103 104 [105] 106 107   next >   >>
Login
RE: Blade CX-2 - 4/30/2008 4:45:22 PM
rocket-ron
Status: offline
Here's a pic. of the fleet! (Pee Wee,and his bigger brother BH450SE) Ron
(in reply to rocket-ron)
       Post #: 2601
RE: Blade CX-2 - 4/30/2008 7:13:46 PM
Crusader23
Status: offline
quote:
ORIGINAL: rocket-ron
Crusader23 ,did you change out the stock motors for the BB 180's? Man they do have allot more power! And run way cooler too. I don't think they are any faster,but have much more power. When you cut the throttle,the blades just stop,instead of spinning down,slowly. They say (boomtown hobbies) that the genII motors (not out yet,have even more power)! I dorked mine in last night doing funnels,and got a little too far sideways,right above the ground. When the blades hit the grass,they shattered like they were made out of glass! I gotta get the alum grips,and pivoting (tough) blades on this heli. I timed (on the DX7 counter) my last flight last night,and flying figure eights,funnels,and just plain circuts around the yard,I got right at 9 minutes flying time. Xtreem has a 20C battery for the blade,and I'm thinking about getting one of them. The common sense battery's sofar work well,the E-flite (stock) battery is the worst sofar. It flys well,but dosen't last as long,and is the higest of them all,price wise. Ron
Ron,
I did have the Xtreme motors on mine, but for some reason they died I'm currently rockin' with the stocks until the GENII Xtreme comes out. I also use a 15C 850MaH battery for the BCX. I stil call mine a BCX, because it was originally a BCX that was converted over. I broke a blade last night doing CAV take-offs in the hanger last night. I lost sight of it after it went outside and I couldn't see it anymore...LOL. My E-flite batteries run me about 10+ mins still and the MAX are about the same. I just set the timer for that long. Anyway, get some new blades on and continue flying missions
Kenn
_____________________________
5 more months and I''ll be home
       Post #: 2602
RE: Blade CX-2 - 5/2/2008 2:13:54 AM
casey_lamm
Status: offline
anyone that has one...
wondering what might be wrong.. full right rudder spins the heli at 2 or 3 x the rate as full left. What could be wrong or is this normal.
(in reply to Crusader23)
       Post #: 2603
RE: Blade CX-2 - 5/2/2008 2:22:09 AM
rocket-ron
Status: offline
Mine will piro to the right faster too! Not sure,but it has something to do with the motor tourque? Also when banking to the left it will hold altitude,but bank to the right,and it looses altitude.I think this is just "normal for coaxle helis. Ron
< Message edited by rocket-ron -- 5/2/2008 2:43:31 AM >
(in reply to casey_lamm)
       Post #: 2604
RE: Blade CX-2 - 5/2/2008 2:25:49 AM
casey_lamm
Status: offline
ok, I have the same thing while turning.
       Post #: 2605
RE: Blade CX-2 - 5/2/2008 2:41:51 AM
rocket-ron
Status: offline
quote:
ORIGINAL: casey_lamm
I think when you adjust the porpotional,it adjust the motors to be in (sync),but when you pior,or turn the outside motor slows down,(or speeds up?) anyway, the other motor's tourque takes over,but by one motor slowing down you loose lift. I've also been told that if the gain is right at being too high,just below the (tail wagging) that will effect the turning also,as the "gyro" is fighting the heli. I run mine pretty loose,and it gives me better rudder control. Ron
       Post #: 2606
RE: Blade CX-2 - 5/2/2008 3:07:48 AM
casey_lamm
Status: offline
humm...complicated...guess im not going to fight it...just fly.
       Post #: 2607
RE: Blade CX-2 - 5/2/2008 10:00:02 AM
Crusader23
Status: offline
Nothing's wrong with the heli. This coax uses the bottom blades as the main and the top ones are the "anti torque" per se'. Since there's no pitch for the anti-torque, the motor adjusts the speed on how fast or how slow the top one spins. This makes it spin to the right faster because the main baldes are being reduced, while the top ones are turning faster. Plus the fact that there are less rotating parts on the top baldes compared to the lower blades, thus producing more spin/thrust. The opposite applies for left and since the main blades have more things attached to it, the slower it turns the heli to the left.
Hope that kind of clears thing out for you.
Kenn
       Post #: 2608
RE: Blade CX-2 - 5/4/2008 1:55:54 AM
rocket-ron
Status: offline
quote:
ORIGINAL: Crusader23
Ron,
Kenn
Yeah,Kenn! I get about 9:30 out of my packs (Common Sense). My original E-flite battery is goi'n South,though. I get less,and less time on it every charge. I'm down to around 5 min tops on it,but I beat my batterys like a rented Mule they don't get much rest between flights. Ron
       Post #: 2609
RE: Blade CX-2 - 5/4/2008 9:00:26 AM
Crusader23
Status: offline
Ron,
There’s nothing wrong with a rented mule. At least they're not being violated by owners like we sometimes see here. I've been using the heck out of my batteries. I used to fly about 10 packs with two batteries on a daily basis.
BTW, does anyone know what settings I need to make the CX2 tail pretty solid in flight? I've heard that one can make it like it has a HH gyro installed on it. Any suggestions would be greatly appreciated.
Kenn
       Post #: 2610
RE: Blade CX-2 - 5/17/2008 3:28:31 PM
nomobux
Status: offline
Well .. I just made it thru 105 pages. I figured I'd read everything I can find before I do my thang !! One thing comes to mind. EXACTLY what it the diff between the 4 in 1 and the newer 3 in 1, which I have ? thanx. I'm sure I will be back alot.
" I GOTTS NOMOBUX "
       Post #: 2611
RE: Blade CX-2 - 5/17/2008 3:43:55 PM
DrunkYoda
Status: offline
As I thought the 3-in-1 doesn't include the receiver so you'll need an external Rx like an ar6100 or something that meshes with your transmitter.
For the average Joe you'll need a 4-in-1.
RX, mix, esc, gryo = 4
mix,esc,gyro = 3
(in reply to nomobux)
       Post #: 2612
RE: Blade CX-2 - 5/17/2008 4:09:05 PM
nomobux
Status: offline
quote:
ORIGINAL: DrunkYoda
mix,esc,gyro = 3
I meant the new CX2 comes with the 3 in 1 and what is the diff between that and the older ones with the 4 in 1
" I GOTTS NOMOBUX "
(in reply to DrunkYoda)
       Post #: 2613
RE: Blade CX-2 - 5/17/2008 4:16:46 PM
DrunkYoda
Status: offline
That is the difference there must be an external receiver somewhere other than in the
