RE: Blade CX-2
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Blade CX-2
Page: <<   < prev  99 100 101 102 103 104 105 [106] 107 108   next >   >>
Login
RE: Blade CX-2 - 5/24/2008 10:56:41 AM
Crusader23
Status: offline
quote:
ORIGINAL: chris1379
Make sure neither shaft is binding and try binding the receiver again.
Chris
Did both of those already. C'mon we can solve this issue. There's got to be something out there that's causing it.
_____________________________
4 more months and I''ll be home
(in reply to chris1379)
       Post #: 2626
RE: Blade CX-2 - 5/25/2008 1:28:50 AM
choppersrule
Status: offline
Crusader23,
Turn the gyro all the way CCW, then re-adjust the proportional. Hope this tid bit works for ya.
Dave / Choppersrule
quote:
ORIGINAL: Crusader23
quote:
ORIGINAL: chris1379
Chris
"Flying is learning how to throw yourself at the ground and miss"
(in reply to Crusader23)
       Post #: 2627
RE: Blade CX-2 - 5/30/2008 2:06:20 PM
nomobux
Status: offline
Sheeeezus .. I read 105 pages, get a BCX2 .. everyone leaves !!!! Maybe I should take a bath.
" I GOTTS NOMOBUX "
(in reply to choppersrule)
       Post #: 2628
RE: Blade CX-2 - 5/30/2008 4:15:26 PM
UTM
Status: offline
quote:
ORIGINAL: nomobux
Don't feel bad. it was 96 pages when I first got my CX2. I did the same thing as you did, read it all and then the thread dried up or I thought it did. If you post questions you will get your answers as most still follow the thread but have moved on to bigger helis myself included. I still fly the CX2 regularly though as it's a really fun little dude.
Rules are made for people who aren''''t willing to make up their own....Chuck Yeager
(in reply to nomobux)
       Post #: 2629
RE: Blade CX-2 - 5/30/2008 5:28:24 PM
StoneGod
Status: offline
Hi all, I've been dead and gone for a long time, but I'm back with a quick question for those who know regarding upgrade rotors.
I've been looking at either trying the Xtreme (from XtremeProduction) rotor blades or the AFC System (so call "indestructable" blades) blades on my CX2.
Has anyone tried both, and found one to be significantly better than the other?
Is there a consensus on what blades offer the best performance with the CX2?
Other than that, I think I'm good to go with my first Heli!
Thanks for the info. and feedback.
Best regards.....
       Post #: 2630
RE: Blade CX-2 - 6/1/2008 7:50:16 PM
bronxsta79
Status: offline
Sup all, First of all lemme say thank you for all the knowledge and info found in this thread. Picked up a cx2 about a week ago and absolutely love it. Got a problem with proportional though.
I have it set as far as it will go clockwise to stop the constant nose turning to the left. Halfway through the pack I wind up with the trim all the way to the right also. I'm pretty sure I just need to adjust the servo arms and center the swashplate but I can pretty much hover hands off with everything set. I plan on putting in the aluminum lower and swashplate so maybe after that I will adjust everything. The blades are balanced and I havnt crashed so I know no shafts bent. Besides that in a matter of 2 days I said goodbye to the training gear and hello to the xtreme skids, boom kit, and canopy. Love the way it looks now. Here is a pic of my bird so far. Any advice would be cool.
Thanks again for all the help guys.
(in reply to StoneGod)
       Post #: 2631
RE: Blade CX-2 - 6/1/2008 10:19:41 PM
StoneGod
Status: offline
Hi Bronxsta79,
Are you still running your CX2 on the stock e-flite lipo? If so, that may be part of the issue with you starting to turn 1/2 way through your fly time and not a setup issue. The CX2 will start to lose its proportional settings/setup as the battery weakens.....Answer: Upgrade your lipo to a good one I like the 850-900mah with a min. of 15C rating (the stock E-flite one is only about a 8-9C and in my experience is crap). You can get a MUCH better batter pack for 1/2 the price of the stock E-flite ones. MEGAPower, SMC, DN, and Kong Power are all good one to go with so far as I know I have yet to figure out if one is better than the others, but I'm working on it.
Hope this helps.
(in reply to bronxsta79)
       Post #: 2632
RE: Blade CX-2 - 6/6/2008 11:05:30 PM
Deftones123
Status: offline
what lipo packs are you guys using instead of the stock e-flite packs, I want something around the same size pack but alot cheaper?
       Post #: 2633
RE: Blade CX-2 - 6/7/2008 1:01:58 AM
casey_lamm
Status: offline
Im using DN's
(in reply to Deftones123)
       Post #: 2634
RE: Blade CX-2 - 6/7/2008 6:37:25 AM
hellblastervolly
Status: offline
Im with Stone the E-flite pack don't last long and you have to keep triming through the duration of the fly.
Fernando
" A Pilot Has To Do What A Pilot Has To Do To Fly "
(in reply to casey_lamm)
       Post #: 2635
RE: Blade CX-2 - 6/7/2008 9:35:55 PM
Deftones123
Status: offline
anything cheaper then the 30 dollar e-flite pack
(in reply to hellblastervolly)
       Post #: 2636
RE: Blade CX-2 - 6/7/2008 10:09:08 PM
cwharper
Status: offline
Here's what I found,
http://www.commonsenserc.com/index.php?cPath=37_35
http://home.comcast.net/~truerc/ready_pack/ready_packs.htm (look toward the bottom)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTCZ5&P=7
I have three of the flightpower packs and they work great, however, my original eflite pack still works too. I might lean toward trying what truerc has if I buy another.
Disclaimer: My CX2 is now brushless and runs more efficient.
When you see the mushroom cloud, you will know then that I have finally achieved fusion.
       Post #: 2637
RE: Blade CX-2 - 6/19/2008 9:14:15 PM
Deftones123
Status: offline
does anyone know if the esky lama packs will fit the cx2 or work with the cx2?
(in reply to cwharper)
