bucky242
Joined: 10/2/2007 From: Fond du Lac, WI, USA Status: offline
I've got two from a friend that works at eaa (oshkosh i live 17 miles south) While taxiing out in sequence behind a Lufthansa airliner at Frankfurt, a C-130 crew noticed an orange "Remove before flight" streamer hanging out of the Lufthansa nose wheel well (their nose gear locking pin was still installed). Not wanting to cause too much embarrassment by going thru the controller, the 130 crew simply called the Lufthansa aircraft on the tower frequency: "Lufthansa aircraft, Herky 23." No reply. They repeated the transmission and again there was no reply. Instead, the Lufthansa pilot called the tower and asked the tower to tell the Herky crew that "the professional pilots of Lufthansa do not engage in unprofessional conversations over the radio." The 130 pilot quickly replied, "Frankfurt tower, can you please relay to the professional pilots of the Lufthansa aircraft that their nose gear pin is still installed?" While taxiing out for takeoff, the Boeing 727 suddenly came to a stop. With the aircraft still on the taxiway, the flight attendant in the back began to lower the aft stairway. Behind the plane, a van with flashing lights came to a screeching halt and out jumped three deadheading pilots (a pilot riding a long to get to a different airport from there hub). They grabbed their bags and ran to the plane. As they ran up the stairs, the pilot in front continued running up the aisle shouting, "I can't believe the stewardess got the plane this far. I didn't know she even knew how to start the engines!" For a number of passengers it took quite some time before they realized they had been had by these jokers, you couldn't believe the startled looks on their faces!
