RE: Sig Rascal 110    Gallery
Logged in as Guest
    Search This Thread
Printable Version
42% Radiocraft Extra 330 with DA 150 and mufflers - RTF
Seller:  hatstien
Details:   $1,750.00   |  5/8/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Sig Rascal 110
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: Sig Rascal 110 - 9/13/2010 10:09 PM
pegmal
Score: 100
Last Login: 12/31/2012
Status: offline
Hello all, I just bought a used Rascal 110 that has an OS 160 on it.
I got to fly the plane this weekend and it was great, plenty of power from that os 160.
I am thinking about changing it out to gas. I have read the entire thread and found it most interesting. It seems to me the Zenoah 26ei might be the one. I'll need a new cowl, which I have found, but don't know if I need the extended cowl 7 1/2 inches on the regular one? Would someone please answer this question - I didn't see it in the thread. Thanks in advance - malcolm
Hide Signatures
(in reply to Temple)
       Post #: 376
RE: Sig Rascal 110 - 9/13/2010 10:48 PM
king_arthur1953
Score: 100
Last Login: 2/1/2013
Status: offline
The standard cowl is fine. I have the Zenoah 26E in mine and the standad cowl.
_____________________________
Ron Mallonee Waco Brother #130
"A man of good character is known for what he does when no one is looking."
Hide Signatures
(in reply to pegmal)
       Post #: 377
RE: Sig Rascal 110 - 9/13/2010 10:52 PM
Hogrider
Score: 100
Last Login: 5/19/2013
Status: online
Me too.
I had the G26 with a 5/8" or 3/4" firewall mount spacer.
Hogrider
THINKING IS HARD WORK!!
Hide Signatures
(in reply to king_arthur1953)
       Post #: 378
RE: Sig Rascal 110 - 9/13/2010 11:23 PM
pegmal
Score: 100
Status: offline
Thanks King Arthur and Hogrider for the quick responce with the answer to my question - I'll be watching this thread since I'm a 110 owner hi hi.
From some of the other information I got from the thread - I'll be looking in to a 3 1/2 inch spinner and a B & B header stack ( think that might be a muffler hi)
Hide Signatures
       Post #: 379
RE: Sig Rascal 110 - 9/14/2010 1:51 AM
Hogrider
Score: 100
Status: online
I used a 3-1/4" TruTurn Spinner (TT-3552-B ) or a TruTurn
3-1/2” Ultimate Spinner TT-3552-B-M. Be sure to get the proper dome cut for the prop you will be using. Not all props have the same cut-out for the same pitch. Do some research on TruTurn website.
You can hide (blend-in) a B&B Header Single Stack better (not as bulky) than a B&B Double Stack.
Hogrider
Hide Signatures
       Post #: 380
RE: Sig Rascal 110 - 9/14/2010 2:01 AM
Hogrider
Score: 100
Status: online
This forum with "pittsman", "king_arthur1953" and some others have been a wealth of design and modification ideas for me and I thank them very much for their contribution.
Hogrider
Hide Signatures
       Post #: 381
RE: Sig Rascal 110 - 9/14/2010 2:16 AM
king_arthur1953
Score: 100
Status: offline
Thanks Hog Rider. I use the single pipe header. Load but good. I use the same TT spinner as Zippi had on his. BTW i ride a 03 Heritage softail classic anniversary.
Hide Signatures
(in reply to Hogrider)
       Post #: 382
RE: Sig Rascal 110 - 9/14/2010 7:44 AM
pegmal
Score: 100
Status: offline
Again Hogrider, thanks for the heads up on the tt spinner and the single header - I've already been over to their site and saw how the match up the proper prop nuts to the right motor - I really appreciate all your information - malcolm
Hide Signatures
       Post #: 383
RE: Sig Rascal 110 - 9/20/2010 1:26 AM
pegmal
Score: 100
Status: offline
Hey I have another question - Just got in from flying my Rascal - it has the os 160 which is really a nice motor. I think I would be more happy if I change it out to gas. The question is, I have been given advice from king arthur and hogrider on using the Zenoah 26ei, which I thank them very much. I have a good lead on an Zenoah 23 - which I know does not have electronic ignition. This Zenoah 23 is brand new in the box - could I tell much difference between the 26 or the 23 ? Looks like the price will be around $185.00. Like to hear again for king arthur and higrider and anyone else - If you think I should wait for the Zenoah 26ei please just say so -thanks in advance malcolm
Hide Signatures
       Post #: 384
RE: Sig Rascal 110 - 9/20/2010 2:17 AM
Hogrider
Score: 100
Status: online
A G26 is an improved G23.
I had a G26 Mag that came with a SIG Rascal 110 and changed it over to electronic ignition.
I did fly it with the Mag, but I felt it idled a little too fast. With the electronic ignition, the idle was much lower and smoother.
Another possible draw-back is the fly-wheel effect, if you want to come down from full open to idle. The fly-wheel will want to keep on spinning. The Mag needs to spin fast in order to fire, where the electronic ignition will fire at about 2 or 3 RPM.
Just something to consider, I think you would be happier with a G26 Electronic Ignition.
Hogrider
Hide Signatures
       Post #: 385
RE: Sig Rascal 110 - 9/20/2010 3:01 AM
Hogrider
Score: 100
Status: online
Something else "pegmal" will want to consider if decides to go with the G26, is to replace the Prop Hub with a BH Hanson Hub that uses a prop bolt. The tensil strenght of the stock prop shaft is not good.
I have a 1979 Super-Glide. I have really negelced the Hawg and she needs a lot of TLC.
Hogrider
Hide Signatures
       Post #: 386
RE: Sig Rascal 110 - 11/16/2010 7:17 AM
pegmal
Score: 100
Status: offline
Got my G26 mag, my question is,I want to use A wrap around
pitts muffler. Will that Set up work with the new cowL
I bought. Not the.extended one
Thanks malcolm
Hide Signatures
       Post #: 387
RE: Sig Rascal 110 - 11/16/2010 7:48 AM
Hogrider
Score: 100
Status: online
I am not sure about the Pitts Muffler system. It seems most use the B&B Muffler or the B&B Header Pipe. I have used both B&B Systems. The Header gives the cleanest installation.
Hogrider
Hide Signatures
       Post #: 388
RE: Sig Rascal 110 - 11/17/2010 12:50 AM
elit95
Score: 100
Last Login: 2/4/2013
Status: offline
Hey All,
I'm thinking of selling my Blue/White Rascal 110. It's equiped with the G26ei, single Bennet Built muffler, True Turn spinner, SmartFly electrical cutoff, JR 126MG servos, Pilot figure, 2400/4.8 NICD ignishion, 1500/6 NICD reciever and 2.4 spectrum receiver. Only damage was caused by my over shrinking the top covering of the wing where the blue transparent covering underlies the white. DARN it! But that has been repaired but barely detectable. Overall great shape
2 questions
1. What is a fair asking price
2. Is there any interest
Jim from Iowa
Jim and Eli
Father and Son~ Team Abby Normal
Hide Signatures
       Post #: 389
RE: Sig Rascal 110 - 11/17/2010 1:34 AM
Hogrider
Score: 100
Status: online
You may be shocked at the offers being tendered (some would say it is depressing). The market is really down from a year ago.
There is a lot of window shoppers (nothing wrong with that), but no one wants to part with their green-backs. Not that much disposable income, if any. This is not news to anyone out there, but times are tough.
There is a lot interest, but little money to spend.
Hogrider
Hide Signatures
(in reply to elit95)
       Post #: 390
RE: Sig Rascal 110 - 11/17/2010 9:53 PM
jbarnes
Score: 100
Last Login: 5/14/2013
Status: offline
50% of new seems to be the going rate these days. At least thats what I've been getting for nice used planes. Jerry.
Longmont Aircraft Modelers Association
Longmont, CO visit our site at www.lamarcclub.com
Hide Signatures
       Post #: 391
RE: Sig Rascal 110 - 2/5/2011 9:37 PM
A1
Score: 100
Last Login: 3/5/2013
Status: offline
Since the Rascal 110s are gone, are there any planes out there that flew almost as good. I never got a chance to buy a Rascal. Thought about a Cub but was told just not the same to have fun with.
I said,"watch this", then.......
Hide Signatures
(in reply to jbarnes)
       Post #: 392
RE: Sig Rascal 110 - 2/5/2011 10:13 PM
Hogrider
Score: 100
Status: online
I am in the process of re-building the nose of mine.
The Rascal 110 is just a big trainer and a real joy to fly.
There is still a few out there to buy already built.
The SIG 1/4 scale Cub is in my staging area waiting its turn to get built.
Should be fun, but not like the Rascal 110.
Hogrider
Hide Signatures
(in reply to A1)
       Post #: 393
RE: Sig Rascal 110 - 8/13/2011 4:20 AM
Brian Smith
Score: 120
Last Login: 4/14/2013
Status: offline
Who was looking for a Rt wing? Broke my rascal 110 pretty bad. need to buy a left wing or sell a Rt one.. Brian
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
Hide Signatures
       Post #: 394
RE: Sig Rascal 110 - 8/13/2011 5:31 AM
Hogrider
Score: 100
Status: online
Hi,
How much do you want for the right wing?
You can PM me with the details.
I am also going to re-build another 110 Rascal and can use a set of wings. Color doesn't matter.
Feel free to PM me what you have and the condition they are in.
Hogrider
Hide Signatures
(in reply to Brian Smith)
       Post #: 395
RE: Sig Rascal 110 - 8/13/2011 8:08 PM
Brian Smith
Score: 120
Status: offline
110 Rascal parts. What happened? Don't ask. .. I have a very nice clean right wing. Blue and white. I have a nice clean strut, a wing joiner and a cowl cut for a DLE 20. A box big enough to ship it in is $12. I want $140 shipped to even think about packing it up and shipping it. I have pictures of the parts if any one wants to see them. email your email address at ivabrian at lighttube.net.. Thanks Brian
Oh BTW. These items are all free to anyone who will stop by Tullahoma or a near vicinity and get them. Brian
< Message edited by Brian Smith -- 8/14/2011 12:58 PM >
Hide Signatures
       Post #: 396
RE: Sig Rascal 110 - 11/22/2011 1:09 AM
Hammbone
Score: 100
Last Login: 4/30/2013
Status: offline
Looks like Sig has a new version of the Rascal 110 due out soon. I'm looking for a good, fun float plane.
Does anyone know if the DLE 30 engine would be a good engine choice for this plane?
Jim
Hide Signatures
       Post #: 397
RE: Sig Rascal 110 - 11/22/2011 1:21 AM
mogman
Score: 100
Status: offline
I have G26 EI on mine, with floats...more than adequate power....flies around at 1/3 throttle
Hide Signatures
(in reply to Hammbone)
       Post #: 398
RE: Sig Rascal 110 - 11/22/2011 1:56 AM
Hammbone
Score: 100
Status: offline
Thanks mogman,
The DLE 30 is lighter, and maybe more powerful than the G26EI? I'm just wondering if the DLE 30 would fit in the cowl well. I thought maybe someone would have tried it on the Rascal and could let me know.
I hope they are planing to sell the floats again, along with the new version of the Rascal 110. I moved into a house on a lake earlier this year, and I'd love to have one of these Rascal 110's on floats. I had a Rascal 40 about 15 to 20 years ago, and I could not believe how well it flew!
Thanks, Jim
Hide Signatures
(in reply to mogman)
       Post #: 399
RE: Sig Rascal 110 - 11/22/2011 1:59 AM
Brian Smith
Score: 120
Status: offline
When I bought mine it had a G26 on Cunningham ignition. I love my G26s and Ralphs are the best.. I hate to say it, but I took it off and installed a DLE20. It fit the cowl and had more power than the G26. Brian
quote:
ORIGINAL: Hammbone
Jim
Hide Signatures
       Post #: 400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
