Kdill2160
Score: 100 Joined: 9/7/2006 Last Login: 4/14/2009 From: McHenry,
IL, USA Status: offline
As promised... -------------------------------------------------------------------------------- I need to learn to prpogram my JETI Spin ESC and I thought I'd take a look at the instruction manual for the JETI Box Programmer... WOW, there are so many programamble features... and Get this: It appears it can be used as a "Data Logger" too... Very Kewl...(I don't think my micros could lift it in the air...I'd bet the minis can!) Here's a list of the programable features as shown in the manual, It has four or five main menu selections which take you to individual sub-menus... From there it's almost overwhelming the amount of features it has...Looks like the programmer is THE best way to get the most of out of the JETI SPIN line of ESCs as the options from the Jeti box are much more extensive than the options for stick programming the same ESC... Here's the menus: Controller Type--->Basic Data Measure or Setting ---> Measure---> Man Setting---> Auto Set ---> Measure---> Max temperature, Min Temperature, Actual Temperature, Max Current, Min Current, Max Voltage, Min Voltage, Actual Voltage, Off Voltage, Motor Run TIme, Power On Time, Motor Pole Number, Gear, Max Motor RPM, Max Prop RPM, Errors. Man Setting---> Temperature Protection, Brake--> Addl Brake Settings, Operation Mode-->Addl. Mode Settings, Timing, Frequency, Acceleration, Accumulator Type--> Addl. Settings, Number Of Cells Lilo/po/Auto, Lilo/po/ Cut Off Volt Per Cell, Off Voltage Set, Cut Off, Initial Point Auto--> Addl. Settings, End Point, Auto Inc. End Point ON From-->Auto Increment End Point OFF, Throttle Curve, Rotation, Timing Monitor. Auto Set---> Acro Inrunner, Acro Outrunner, Glider Inrunner, Heli Constant RPM, Heli Constant RPM 3D. As you can see the programming features are very extensive with the JETI BOX and JETI SPIN line of ESCs... I hope you find this info usefull... Ken
_____________________________
UP = AWAY FROM THE CENTER OF THE EARTH AMA 768718 IRCHA 2682
Hide Signatures
