RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/16/2007 4:42 PM
Oscardms
Score: 100
Last Login: 9/7/2008
Status: offline
He probably meant that the only change to his truck would be to get the roto start system swapped. I actually just did it last night and it was so easy. I didn't even have to take the motor off the truck.
Hide Signatures
(in reply to lewis_lfc)
       Post #: 226
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/16/2007 7:54 PM
hazegry1
Score: 100
Last Login: 10/24/2009
Status: offline
yea that is what I meant the roto start will probably be my only mod for awhile. I might upgrade other things later but the roto start will be the first mod for sure
Hide Signatures
(in reply to Oscardms)
       Post #: 227
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/17/2007 1:41 AM
SioXiE
Score: 100
Last Login: 7/19/2008
Status: offline
im planning to buy the firestorm (i been researching for a while) 2-3 days from now but my concern is the pullstart mechanism, since im a newbie i want t ask u guys how to replace it with a rotostart system???
_____________________________
Bash Till IT Breaks!!!!!
Hide Signatures
(in reply to hazegry1)
       Post #: 228
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/17/2007 1:43 AM
SioXiE
Score: 100
Status: offline
and i check on the hpi website, does the rotostart system comes with all the necessary hardware? ad can swap the pullstart without taking out the engine???
Hide Signatures
(in reply to SioXiE)
       Post #: 229
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/17/2007 3:05 AM
hazegry1
Score: 100
Status: offline
from what I have read you can swap it out without removing the engine but, you will also need to buy the backplate when you buy your roto start.
Hide Signatures
       Post #: 230
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/17/2007 3:15 AM
Oscardms
Score: 100
Status: offline
quote:
ORIGINAL: SioXiE
No need to be scared. Trust me. This is my first Nitro car and it was a breeze. Like I said before, you don't even need to take the motor off the car. You'll need to order or buy two parts at your LHS. First is the backplate to fit our car. HPI number 87117. Second is the rotostart system itself. HPI number 87110. The system comes with a backplate already but it is for the savage. The rotostart system you can probably buy for cheaper on ebay used. The system and the backplate each come with instructions and they tell you what to do step by step. Each piece even comes with the screws and the allen wrench to take them off and on. Just make sure you have threadlock. If you need detailed instructions, you can PM me.
Hide Signatures
       Post #: 231
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/20/2007 7:31 AM
dcep28
Score: 100
Last Login: 3/6/2008
Status: offline
Does anyone know if Parma has a body for the FiReStorM?
Hide Signatures
       Post #: 232
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/20/2007 11:21 PM
SioXiE
Score: 100
Status: offline
thanks for da nfo HAZEGRY1 n OSCARDMS, I went to my LHS to check it out but instead brought me a SAVAGE X to be my first Nitro truck... merely to peer pressure!!! all my friends have monster trucks, but im stil planning to buy a Firestorm in the next couple of months!!!
Hide Signatures
(in reply to dcep28)
       Post #: 233
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/20/2007 11:27 PM
SioXiE
Score: 100
Status: offline
Mabuhay ka dcep28!!!!
Hide Signatures
       Post #: 234
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 12:06 AM
dcep28
Score: 100
Status: offline
Thanx 4 da Shout-Out SioXie..
Hide Signatures
       Post #: 235
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 3:37 AM
20%nitro
Score: 100
Last Login: 6/23/2009
Status: offline
sorry to barge in here but i thought you guys might find this as funny as i did.
http://www.heartlandrc.com/forums/showthread.php?threadid=2133
mbx5 prospec ws7,ttr st1 c6bb,jmn crt axial 28,firestorm,18t,detta,tc3 mamba 7700 dirt oval
Hide Signatures
       Post #: 236
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 5:32 PM
Oscardms
Score: 100
Status: offline
Hey guys, I''m having a hard time starting my truck up every time I try. I haven't broken it in fully yet. I have used after run oil, after every time I turned the truck on. The only thing I've done to the truck is to install the rotostart. The plug is still good. Can anybody help out.
Hide Signatures
(in reply to 20%nitro)
       Post #: 237
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 6:04 PM
HPIFIRESTORM
Score: 100
Last Login: 5/16/2008
Status: offline
Double check the all the bolts on the motor, some people have found there's to be loose, therefore causing starting problems.
Hide Signatures
       Post #: 238
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 7:02 PM
20%nitro
Score: 100
Status: offline
it is possible you are using too much after run oil. i recomend if you are going to run it every day or so two only put in 2 or 3 drops at the end of day. it is possible to soak the glow plug with oil and that could make it very hard to start. also check the condition of the glow plug making sure the coils are perfect and not distorted and that it glows really bright when you stick it in the glow igniter to test it. as oscardms said check the head bolts, some have come loose. are you emptying the tank and fuel system also at the end of day? if so it may require more prime time or to blow on the pressure line to refill the system. one last thing, if your idle speed is too slow it may require a helper to hold the trigger just above idle until it starts. hope this helps.
Hide Signatures
       Post #: 239
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 7:30 PM
Oscardms
Score: 100
Status: offline
I've only been using 2-3 drops of after run oil at the end of the day. I let it soak in for a couple of mins. and then I'll turn it upside down to make sure any excess comes out before I put fuel through it. The glow plug glows real bright when I test it. As far as loose screws on the motor, which ones should I take a look at? The ones connecting it to the chassis, or the ones holding the head onto the motor? Thanks for the help guys.
Hide Signatures
       Post #: 240
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 7:56 PM
buggymangp
Score: 100
Last Login: 7/25/2008
Status: offline
the screws holding the cooling head to the block.
i`m watching this post beacuse i`m still looking to buy a firestorm someday.
Hide Signatures
       Post #: 241
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 8:34 PM
Oscardms
Score: 100
Status: offline
Cool. Thanks. This is my first nitro.
Hide Signatures
(in reply to buggymangp)
       Post #: 242
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/21/2007 9:10 PM
Hellacool
Score: 100
Last Login: 2/22/2008
Status: offline
I am looking to purchase a 2WD truck for racing only. I already have 2 x HPI MT2s, a Traxxas Stampede and a Duratrax Evader Pro. They are my "fun" trucks. The Firestorm seems to be the right price and quality. I already have two rotostarts so that is a quick upgrade. My question is??? Are there any areas on the firestorm that will need upgrading off the shelf? I know on my MT2, the steering knuckles and C Hubs are weak and need upgradeing. What about the Firestorm? Thanks. I also plan to upgrade the radio as well.
Hide Signatures
       Post #: 243
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/23/2007 4:00 AM
20%nitro
Score: 100
Status: offline
oscardms what is the temperature in the area where you start the truck? if it is cold like 60 deg or colder try using a blow dryer to warm up the cooling head before starting the engine this should help. once you have the engine broken in and tuned this may not be as necessary but usually helps even then. again set the idle fast enough to keep it running but not so much as to make it drive away.
Hide Signatures
       Post #: 244
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/23/2007 4:13 AM
20%nitro
Score: 100
Status: offline
hellacool i have raced my firestorm twice and the only problems ive had are the pipe coupler between the header and muffler gave out in the first few laps. a new hd coupler fixed that quickly and cheeply. the only other problem is with the steering servo saver. seems to work loose and is hard to adjust. i hope they upgrade that. if the price works for you and since you want race it i think the spektrum dx2 radio system is good and no freq problems and you can work on the car in the pits with the radio gear on while others are racing if your track allows it.
Hide Signatures
(in reply to Hellacool)
       Post #: 245
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/23/2007 5:32 AM
Oscardms
Score: 100
Status: offline
quote:
ORIGINAL: 20%nitro
Thanks. I actually went to my lhs today because my rotostart system stopped working. I took my truck in and the guy made some adjustments and it started no problem today. Thanks for all the info though.
Hide Signatures
       Post #: 246
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/23/2007 9:51 AM
Hellacool
Score: 100
Status: offline
quote:
ORIGINAL: 20%nitro
Thanks. I see al kinds of cars but it always seems to make them work somthing needs to be upgraded. I still havent decided yet but the Firestorm is at the top. For about $200 more than a Firestorm and Spextrum I can get a Losi 8ight RTR That is on my list as well.
Hide Signatures
       Post #: 247
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/27/2007 1:02 AM
hazegry1
Score: 100
Status: offline
well guys I just ordered my firestorm today. I am starting to save for my hyper 8 project gonna build that one but wanted the firestom for general bashing. mine should be here by this weekend. I am hoping it gets here sooner. went and bough a fuel bottle, glow igniter, some after run oil, and a bottle of 20% today. I can not wait for this weekend
Hide Signatures
       Post #: 248
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/27/2007 9:42 PM
sapper ion
Score: 100
Last Login: 5/11/2009
Status: offline
I have had the Firestorm 10T for about a week. One thing I noticed is after tank 3 it really started to 4 cycle. "I have not tuned it all that much". When I finally did get it tuned I ended up going a full turn lean on the High speed. Now maybe the cold air "29-40 degrees" had a lot to deal with that, but for now it seems to be a lean brat. And even as lean as it is it still has a hard time reaching even 200 degrees. "I don't dare lean it out anymore mainly because i am affraid of engine damage. So what do you suggest I do
Also I am a noob, the only experiance i have in engine work is what I have learned from racing gokart engines and working with my dad on his RC Airplane. So whatever you can give to me for info would be great.
Hide Signatures
       Post #: 249
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/28/2007 2:49 AM
hillbilie
Score: 100
Last Login: 10/28/2009
Status: offline
my firestorm is STILL sitting in my room with a broken bulkhead set, because the part is not out yet
Hide Signatures
(in reply to sapper ion)
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.809RCU1
