RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Tower Hobbies
Logged in as Guest
Users viewing this topic: Kodiac400
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: -=OFFICIAL HPI FIRESTORM THREAD=- Page: <<   < prev  211 212 [213] 214 215 216 217 218 219 220   next >   >>
Login
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/1/2010 9:42 PM
Road Warrior
Score: 100
Last Login: 3/21/2010
Status: offline
I have a 3.0 that I would sell but one of the screws on the back plate is just about stripped from the guy who had it before me. It is sealed up with no air leaks and I did go and mod it too so the bottom and mid range require you to work the trigger for traction. It was pretty much brand new when I got it. It still has the original tires on it and they look brand new too, so I am guessing it has about a quart of fuel through it. I have only drove it maybe 4 times and ran just 2 or 3 tanks each time. I also have 2 big blocks sitting on the shelf ready to rock so it is not necessarily needed.
_____________________________
The road to greatness is paved one mod at a time!
Hide Signatures
(in reply to Blueroost40)
       Post #: 5301
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/1/2010 10:10 PM
Blueroost40
Score: 100
Status: offline
Hey nitro rob, quick question about your idea to buy an OS engine. If i was gonna get an OS it would be a .18 tz, so my question is, would it drop right in, or would some modifications need to be made?
Hide Signatures
(in reply to Road Warrior)
       Post #: 5302
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/1/2010 10:32 PM
Road Warrior
Score: 100
Status: offline
It will drop in but a tz is too much for stock gearing
Hide Signatures
       Post #: 5303
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/3/2010 12:47 AM
Blueroost40
Score: 100
Status: offline
So i would have to get a new diff as well?
Hide Signatures
       Post #: 5304
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/3/2010 1:04 AM
Road Warrior
Score: 100
Status: offline
No just spur and clutch bell. You could keep yours but good luck trying to control it.
Hide Signatures
       Post #: 5305
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/3/2010 3:48 AM
Goldski 2
Score: 100
Last Login: 3/18/2010
Status: offline
ya it dosent matter where u live im in edmonton and i did it also it only 60$
HPI Firestorm
Duratrax nitro evader st
Hide Signatures
       Post #: 5306
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/3/2010 3:51 AM
nitro-rob
Score: 105
Status: offline
I don't know if the TZ bolts right in. Its in this thread somewhere in the past 20-30 pages or so, Constantine (or something like that) put it in, he is in Romania. It was in the middle of the summer or so.
N-Firestorm; E-Firestorm Flux; Savage X SS; CEN 7.7 GST;
Hide Signatures
(in reply to Goldski 2)
       Post #: 5307
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/3/2010 6:57 AM
Road Warrior
Score: 100
Status: offline
The tz comes in 2 ways pull and bump start. Bump start has a sg crank like the 3.0 and a slide carb. Pull has a rotary carb and a threaded crank. Both will need a whole new exhaust and neither a bump box or a shaft extension for the other. Personally the cvr has a little less power and rpm but you wont have to change anything it is a direct fit. It will also be easier to drive it with the same gearing or just replace the clutch bell with a bigger one. You also have to look at the cost of a new piston and sleeve int the future. Tz is $90 and the cvr is $45. It just matters how fast u want to go and how much you want to spend.
Hide Signatures
(in reply to nitro-rob)
       Post #: 5308
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/4/2010 1:09 AM
Blueroost40
Score: 100
Status: offline
2 things. Firstly, Whats kind of carb does the g3.0 have and whats the difference between rotary carb and slide carb? Seconldy, those prices are not the same for where i live. Both the tz and cvr are $150(CAD) easy, if not more.
Hide Signatures
       Post #: 5309
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/4/2010 1:27 AM
Road Warrior
Score: 100
Status: offline
The 3.0 has a rotary too. The slide carb has a smoother power band and it just mounts up differant. You would have to turn the servo around. Those prices were to get new internals after those are worn. The motors are cvr $115 new $45 for piston and sleeve and tz $160 new $90 for piston and sleeve. This was just for future refferance for in the next year or two when it comes to be that time for a rebuild. Personally I would strap a big block in it if you are going to put money into the motor and upgrade it. Take it to the limit like everybody else in the form. Half of the people in here have a big block in their truck.
Hide Signatures
       Post #: 5310
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/7/2010 3:51 AM
Blueroost40
Score: 100
Status: offline
Got some bad new and worse new. Called my kinda lhs(far away to be an actual lhs) and they said they would have a g3 for me on satrday. went today to get it and nope. so the guy there told me a t3 would work fine you just need a pilot shaft extender so got the part and engine and went home. When i got home i found out the motor mounts are too low and the pilot shaft is higher than the g3. Now im screwed til next weekend.
Hide Signatures
       Post #: 5311
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/7/2010 3:52 PM
nitro-rob
Score: 105
Status: offline
Those guys are idiots. These are signs its time to get a 1:1 scale car!
Hide Signatures
       Post #: 5312
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/8/2010 2:57 AM
Blueroost40
Score: 100
Status: offline
Yea, now i gotta call tomorrow and see if they can get a g3.0 by saturday if not im gettin my mony back and going to my lhs.Quick question a little off topic, anyone know how much hobby stores are selling rs4 3 drift's for (not on ebay) and are they any good?
Hide Signatures
       Post #: 5313
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/9/2010 12:51 AM
Blueroost40
Score: 100
Status: offline
called the hobby store, the guy wanted me to mount the engine using the holes on the bottom of the block but i told him theres no holes that line up to those holes on the chassis so he said he'd get a g3.0 by thursday or friday, so looks like im getting my engine this saturday and finally gonna get to rip around a bit
Hide Signatures
       Post #: 5314
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/9/2010 1:51 PM
kilimats
Score: 106
Last Login: 3/2/2010
Status: offline
Hey guys, long time I didn't check this place, hope everyone is ok!
I had a quick question and a new SUPER BRIGHT LED mod to share with you guys, i'll post pics very soon but it's pretty much the brightness flashlight ever mounted in the chassis with a rubber mount, looks awesome ! no custom mod required, i'll post where I got all the parts
Had a quick question too, I need your recommendation on the best battery to fit the Firestorm, I'm looking at the best capacity. I remember someone sharing a cheap LIPO store with good quality back then, you guys have the link handy ? too many pages to go through lol
my SMC 5000mah died on me after storing the cell fully charged for more than 2 month, SMC refused replacing it under warranty , lesson learned, keep it at 7.4V if i'm not using the cell within 1 or 2 days
Hide Signatures
       Post #: 5315
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/9/2010 10:06 PM
kilimats
Score: 106
Status: offline
Here is the mod in question, hope you get inspired (it will make you laugh at the tiny LED canopy mod most do). The flashlight support is strong enough to hold the light during jumps, and i'm also going to add a piece of foam at the front/back to be sure nothing nasty happens. The strap goes around the battery so a hard case is HIGHLY recommended !!
What you need:
A powerful and compact flashlight, here is the one i use, it has the latest and greatest P7 900-Lumen LED : http://www.dealextreme.com/details.dx/sku.12060
If you go with that P7 Flashlight, youll need one Lithium 18650 Batteries and a Lithium charger, here is the battery (there are many charger out there, find the one that meet your need): http://www.dealextreme.com/details.dx/sku.26249
and finally, the CORE item, the flashlight support @ only $3: http://www.dealextreme.com/details.dx/sku.12000
OPTIONAL: a clear canopy to let the light through (but even with the stock canopy, its CRAZY bright): http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPYU1&P=7
Hide Signatures
(in reply to kilimats)
       Post #: 5316
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/10/2010 7:26 AM
estuardon
Score: 100
Last Login: 3/20/2010
Status: offline
I just ordered my Firestorm nitro from towerhobbies since they have a $25.00 dollar off coupon.  To those that have a Spectrum radio with the firestorm, do the receivers fit? and will it work with the stock servos?  Any tips or recommendations budget is $200.00 so its either  DX3E or DX2S
Hide Signatures
(in reply to fasty)
       Post #: 5317
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/10/2010 12:51 PM
kilimats
Score: 106
Status: offline
Estruadon, If I may, your budget could also be a lot less and you would still be getting SUPER quality
Below is a review I made a few month ago about the $80ish tactic 2.4Ghz TX/RX, I still love the setup + I still haven't replaced the TX batteries (I probably did 20 run since then) + I haven't experienced any drop (I always try driving as far as I can too lol), this radio is really impressive for what it cost..I STILL HIGHLY RECOMMENDED IT !!
quote:
First Impression of the tactic 2.4Ghz TX/RX combo from Hobbytowers after a few minutes run (currently @ $80ish with RX)
Pros
Awesome range !!!!!
Interference free !!!! (in my street, stock was loosing signal after 20m, 2.4ghz keep going forever)
Failsafe built in, OMG finally I can drive worry free !
Smoother acceleration and perfect precision even far away (barely see the car)
lighter TX/Rx
Smaller Rx
only 4 AA required
No more gigantic antennas
CHEEEEAAAAAPPPP !!!!!
Cons
Plastic quality a little under the stock TX
often out of stock at towerhobbie (I waited 3 month)
The reverse has a little less play so the car cannot go as fast as with stock TX (still pretty quick anyway), the forward has more play though, not sure if it goes faster, will check
Conclusion: a MUST buy for the failsafe alone !!!
not sure what the RX battery is for, I didnt need it to run the car
Wish I could post pics :-(
Hide Signatures
(in reply to estuardon)
       Post #: 5318
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/10/2010 2:57 PM
nitro-rob
Score: 105
Status: offline
I am a fan of the spektrum setup. The displays are quite good. If the 2s is just like the 3s but with only two channels and two model memory then its a fantastic radio.
I got the tower catalog the other day and the nitro evader costs more than the firestorm. I have both trucks and the evader is not in the same league as the firestorm.
Hide Signatures
       Post #: 5319
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/10/2010 8:50 PM
Road Warrior
Score: 100
Status: offline
Yeah the spektrum radio's are really nice. I had a range issue with my dx3s. Both of the other people I would drive with have the stock am radio's and they could go farther than I could. That didn't upset me as much as if the fail safe would work like it does when it is on the ground in front of you instead of just going where ever it wants to. I had to add 2 more batteries to it and now I can drive it till it disappears. The stock servos will also work fine with it.
Hide Signatures
       Post #: 5320
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/12/2010 3:08 AM
Blueroost40
Score: 100
Status: offline
Hey, i got a question about tools. I know rob you talk about the integy hexes are good, how much would a 2mm, 2.5mm, and 3mm cost? and whats a good t wrench to get that can take of the flywheel nut?(ill be getting a flywheel wrench as well).
Hide Signatures
       Post #: 5321
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/12/2010 3:39 AM
nitro-rob
Score: 105
Status: offline
I paid around 35 for the integy set that had five pieces. The good hexes go for 5-10 each and you can get individual ones. I use the losi T-wrench for flywheel nuts. They are about 8 dollars and are common at most hobby shops. For removing a flywheel the best thing to use is a terminal puller. I got one on ebay for 5 dollars shipped. Its used to remove automotive battery terminals (or you can just tap the old one off)
Check out teamstrc.com. There are a whole bunch of new blitz aftermarket parts available that are compatible with the firestorm. HPI released the Blitz ESE that has a bunch of goodies on it and there are a lot of nice parts there as well. A ball differential is coming for it as well!
Hide Signatures
       Post #: 5322
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/14/2010 9:59 PM
Blueroost40
Score: 100
Status: offline
Hey rob i have a savage question, and i recall you have a couple. Is the 5.9 a major performance upgrade from the 4.6? and which would you say is the best in terms of durability, drivability, and performance?
Hide Signatures
       Post #: 5323
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/14/2010 10:57 PM
nitro-rob
Score: 105
Status: offline
I have no personal experience with the 5.9 but people I know say they are a big upgrade in power. Others say its more worthwhile to get a picco or lrp .28 for the money and performance. Did you get another engine?
Hide Signatures
       Post #: 5324
RE: -=OFFICIAL HPI FIRESTORM THREAD=- - 2/15/2010 5:59 PM
Blueroost40
Score: 100
Status: offline
yea i did, i went on saturday and exchanged the t3.0 for the g3.0. I already got it in and its just waiting for a nice dry day for break-in(just have to lock-tite the engine screws and exhaust manifold screws).
Hide Signatures
(in reply to HotGirl19)
       Post #: 5325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.684RCU1
