RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Firestorm 10T
  • 3 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: -=OFFICIAL HPI FIRESTORM THREAD=-
    Page: <<   < prev  74 75 [76] 77 78 79 80 81 82 83   next >   >>
    Login
    RE: -=OFFICIAL HPI FIRESTORM... - 5/6/2008 11:30:13 AM
    P Bear
    Status: offline
    I use a rotostart on my Savage. Like it more than I thought I would. Use a 3000ma battery and rarely charge it.
    The best thing about the Storm is turning the wheel and locking the brakes at the same time. Once it's sliding sideways hit the gas. That is what two wheel drive is all about. The stock arm on the Storm brake is too short and it comes off at an angle instead of 90 degrees. I attached an aluminum plate to my brake arm that extends out 2" and it's triangle shaped to allow the rod hole to be 90 degrees to the brake shaft. I still have the stock servo and the only time I can't lock up my brakes is when my battery is almost dead.
    (in reply to kordasn)
           Post #: 1876
    RE: -=OFFICIAL HPI FIRESTORM... - 5/6/2008 11:37:43 AM
    tokenring
    Status: offline
    right now I have my HSN at 3/4 turn clockwise and my LSN 1/2 turn clockwise. I think the LSN is horizontal at flush right????
    _____________________________
    *** Eclectic Powered Trucks ***
    (in reply to NitroNate)
           Post #: 1877
    RE: -=OFFICIAL HPI FIRESTORM... - 5/6/2008 5:57:27 PM
    kordasn
    Status: offline
    quote:
    ORIGINAL: P Bear
    Hey P Bear, what did you fabricate the aluminum plate from? I was thinking of using a popsicle stick, I can't really think of anything to use. Did you remove the stock one and put it right into the socket for the brake lever, or did you attach it, if so how?
    Thanks again
    (in reply to P Bear)
           Post #: 1878
    RE: -=OFFICIAL HPI FIRESTORM... - 5/6/2008 5:59:09 PM
    kordasn
    Status: offline
    quote:
    ORIGINAL: tokenring
    On both my G3.0 on the MT2 and on the FS it's vertical when flush, it may be different though, I do not know.
    (in reply to tokenring)
           Post #: 1879
    RE: -=OFFICIAL HPI FIRESTOR... - 5/6/2008 7:28:36 PM
    P Bear
    Status: offline
    I used .105" (2.5mm) sheet alum. from work. Little less than 1/8" thick. Attached it to the old arm. I wanted it the same level with the old arm so I epoxied it to the edge. Worked for about 2 hours run time before it came off. Now I am going to re-attach it to the same spot but use another piece of alum. on top and use 4 small bolts and nuts, 2 on lever and 2 on 2" plate to bolt it on plus use epoxy again. Won't fall off this time. They sell sheet alum. at my local hardware store. Anything between 1/16" and 1/8" alum. would be good. With a popsicle stick you would have a hard time getting 90 degrees to the brake shaft. Doesn't have to be 90, just gives you more leverage.
           Post #: 1880
    RE: -=OFFICIAL HPI FIRESTORM... - 5/6/2008 7:45:59 PM
    tokenring
    Status: offline
    quote:
    ORIGINAL: kordasn
    quote:
    ORIGINAL: tokenring
    I think you're right... the only reason why I wasn't sure is because firstly it is hard to tell by the naked eye (when flush) and secondly when I took it to my local hobby store, they quickly moved it (the leaning way - clockwise) without me looking. It was at 1 o'clock after he they turned it, and I thought he turned it about 1/4 turn. So if I moved it back what they moved it forward, it would be at horizontal. I guess they only moved it a bit... from 12 o'clock to 1 o'clock and not 9 o'clock to 1 o'clock No wonder my engine was flooding previously... Arrrrr!!! Anyway, it's good now!! Thanks for the reply Kordson!!!!
    AB
           Post #: 1881
    RE: -=OFFICIAL HPI FIRESTOR... - 5/7/2008 7:13:35 AM
    tokenring
    Status: offline
    Can anyone say wheelies????
           Post #: 1882
    RE: -=OFFICIAL HPI FIRESTOR... - 5/8/2008 4:28:07 AM
    kordasn
    Status: offline
    quote:
    ORIGINAL: tokenring
    I can't get mine to do wheelies, in grass or pavement or dirt, unless I hit a bump. I have had the HSN turned in fairly far (but it makes it heat up too much), so I have turned it to around 220~240, but I've not seen any wheelies. I suppose I could try the LSN, but I don't know if that would actually help without wrecking the engine. Any help from anyone?
    I read before that if you tighten up the slipper it will wheelie? But it will cause wear on something? What is that thing which will wear?
    < Message edited by kordasn -- 5/8/2008 4:31:56 AM >
           Post #: 1883
    RE: -=OFFICIAL HPI FIRESTOR... - 5/8/2008 8:37:35 AM
    tokenring
    Status: offline
    yeah I just tuned the LSN too a bit and now I can do them on cement, dirt and grass...
           Post #: 1884
    RE: -=OFFICIAL HPI FIRESTOR... - 5/9/2008 2:18:15 AM
    brett65
    Status: offline
    Got my firestorm broke in today! It's my first nitro stadium truck, and man it wheelies almost too easily and just flat out accelerates like a bat out of hades. Anyway, here are some pics. I removed the stock stickers and added a couple of my own. Thought you guys might like the second pic.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Truckzilla Savvy,LRP 28,RS4 Evo3+,Firestorm 10T,Spek DX3.0,Micro-T,Fake ugly stik,SkyRaider Mach 1 w/TTpro 46 Fut 2.4gHz 6EX
           Post #: 1885
    RE: -=OFFICIAL HPI FIRESTOR... - 5/9/2008 4:16:14 AM
    will0983
    Status: offline
    i can not get my firestorm to wheelies at all. Messed with the tuning forever with this thing.
           Post #: 1886
    RE: -=OFFICIAL HPI FIRESTOR... - 5/9/2008 4:54:22 AM
    supersound99ss
    Status: offline
    check ur LSN settings, that was the biggest problem with mine, it was way to rich at idle...also run down the springs on back
    Rustler XL-5 venom 19t fireball, BB, Ram lite Redcat Tornado XL stock HPI Firestorm stock
    (in reply to will0983)
           Post #: 1887
    RE: -=OFFICIAL HPI FIRESTOR... - 5/9/2008 9:47:31 AM
    NitroNate
    Status: offline
    Brett65,that second pic is SWEEEET.Is that one sticker or 1 stuck on top of the other?
    My Firestorm is anti-breakage;
    My MLST2 is garbage.>:(
    (in reply to supersound99ss)
           Post #: 1888
