RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Firestorm 10T
  • 3 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: -=OFFICIAL HPI FIRESTORM THREAD=-
    Page: <<   < prev  75 76 [77] 78 79 80 81 82 83 84   next >   >>
    Login
    RE: -=OFFICIAL HPI FIRESTOR... - 5/13/2008 7:13:43 PM
    motorhead91
    Status: offline
    quote:
    ORIGINAL: scobeh
    when i try to start my motor the roto start just spins does not engage motor ????
    check to make sure your one way bearing isn't on backwards..
    to check just flip it around, and try again
    _____________________________
    Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
    (in reply to scobeh)
           Post #: 1901
    RE: -=OFFICIAL HPI FIRESTOR... - 5/13/2008 7:37:11 PM
    superb3rra
    Status: offline
    Ahh, never mind.. I think the guy i left it with will get it fixed..
    By the way, your photographs on the blue firestorm, is that aluminum front suspension arms?
    (in reply to NitroNate)
           Post #: 1902
    RE: -=OFFICIAL HPI FIRESTOR... - 5/13/2008 7:48:26 PM
    scobeh
    Status: offline
    iam ure i got it in right spins free to the left and catches to the right when i spin it by hand
    (in reply to motorhead91)
           Post #: 1903
    RE: -=OFFICIAL HPI FIRESTO... - 5/13/2008 9:12:41 PM
    NitroNate
    Status: offline
    Yes they are aluminum.Check www.neweramodels.com .
    My Firestorm is anti-breakage;
    My MLST2 is garbage.>:(
           Post #: 1904
    RE: -=OFFICIAL HPI FIRESTOR... - 5/13/2008 10:01:55 PM
    yakfish
    Status: offline
    Finnally got the O.S. 18 CVR installed on the firestorm I got it used but it is still fairly new so I'm driving kindof easy with it now. but I can allready see the power difference in the 2 engines! I put on a 21T clutch bell and it still pulls wheelies with 4 heavy moabs wheels. I would like to figure out how I can go about getting a higher tooth clutch bell. traxxas makes a 24t bell that I think I'mm going to see if it will fit and associated used to make a 26t bell that is discontinued but if I can find one I will try it. there is tons of low end torque so I want to see how fast I can get her to go while still being able to pull wheelies!
           Post #: 1905
    RE: -=OFFICIAL HPI FIRESTO... - 5/13/2008 10:10:08 PM
    NitroNate
    Status: offline
    Hey great Storm yakfish!I'm trying to make my Firestorm into a jato killer!Your well on your way!
    (in reply to yakfish)
           Post #: 1906
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 1:14:19 AM
    tcv_racing
    Status: offline
    Congratulations yakfish!!!
    I hope you can post some pictures and videos soon.. Did you made some cuts on the engine mounts and base plate too? and did you cut the crank shaft also?
    HPI Firestorm 10T
    Tamiya TT01 Rally
           Post #: 1907
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 3:48:35 AM
    yakfish
    Status: offline
    quote:
    ORIGINAL: tcv_racing
    Thanks tcv,
    I'll see about getting some pics up somtime tomarrow. yeah I had to cut the motor mounts to fit the engine I could have cut the base plate but I didn't want to do that kind of cutting on the engine so I put some bushings between the mounts and the chassy of the carto raise it up to clear the back plate. the motor came with a tiger drive that I didn't like so I got a pull start for it. maybe in a year or so when I need more power I'll upgrade to the tz!
    (in reply to tcv_racing)
           Post #: 1908
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 3:58:28 AM
    NitroNate
    Status: offline
    That TZ is crazy!!!!!!!!!!!!!!It could easily power-up a savage!!!!
    I'm thinking about getting one real soon.You need a differant exhaust header and a pilot shaft,right???Could you use the pilot shaft thats on the G3.0??
           Post #: 1909
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 4:10:31 AM
    yakfish
    Status: offline
    http://www.integy.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=4406&p_catid=
    Any one know if This will fit a firestorm. I have been trying to find a gear with a lower tooth count and I think maybe i have!The center hole looks about the same as the factory spur gear.
    quote:
    ORIGINAL: NitroNate
    Yeah you need to get a different shaft for the TZ. The shaft on the G3.0 is all one peice with the crank there were too many things That I was going to need to buy to make it work with my firestorm making it alot cheaper to get the CVR.I think this is the pilot shaft that you would need for the TZ. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXM720&P=7 .A new exhaust manifold to make it fit was going to cost me $45.00 alone! Oh well maybe in the future.
    < Message edited by yakfish -- 5/14/2008 4:13:39 AM >
           Post #: 1910
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 4:22:33 AM
    NitroNate
    Status: offline
    Was the CVR a big differance,in power,speed,rpms.???Is it a direct drop-in??
           Post #: 1911
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 4:33:43 AM
    yakfish
    Status: offline
    quote:
    ORIGINAL: NitroNate
    It is about as direct a drop in that you will beable to find. will will have to cut on the motor mounts a bitI just used my dremel to make them work and I had to reem out the mount holes on the engine. O.S. claims 1.8ps at 29,000 rpm with a practical RPM range of 3000-34000 for $129.99 from tower,and the CVR claims 1.35 PS at 28000 rpm with a practical RPM range of 3000-32000 RPM for $109.99.
    I got mine used on ebay for $72.00. The CVR can use your stock manifold while you do have to get a new manifold to work with the TZ. I would say go with the CVR becuase you can't have a faster storm than me!! .
    seriously if you don't mind spending the few extra bucks go with te TZ! Then go kill some jatos (with the right gearing)!!
           Post #: 1912
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 11:35:37 AM
    superb3rra
    Status: offline
    Hey, the guy i bought it from said i needed special rechargeable batteries, is that true or can i buy normal rechargeable batteries?
           Post #: 1913
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 12:28:21 PM
    NitroNate
    Status: offline
    Yes,get some rechargeble batteries from walmart for your transmitter.(Saves a lot of money in the long run)Also get a HPI hump battery pack.
    (in reply to superb3rra)
           Post #: 1914
    RE: -=OFFICIAL HPI FIRESTO... - 5/14/2008 1:15:09 PM
    tokenring
    Status:
