windowlicker
Joined: 2/21/2008 From: Barton, North Lincolnshire, UNITED KINGDOM Status: offline
quote:
ORIGINAL: motorhead91 yes, in a way you are right..... say for instance the slipper is set as tight as possible, and at idle the truck slightly moves forward, then when you pin the throttle wide open, it does an insane wheelie and gets up too speed quickly now, say the slipper is set extremely loose, and at idle the car sits still, and you pin the throttle wide open, and it sort of "rolls" nice and smooth up to its top speed The car moving at idle is a result of a high idle setting on the engine, not anything to do with the slipper clutch
_____________________________
Hellfire SS - GO .25 - DX3R - 5955TG - 5645MG - Speedtech Carbon
