LA7flier
Joined: 10/18/2002 From: pleasanton, CA, Status: offline
[QUOTE]Originally posted by k_sonn LA7flier: I just added up all of the components needed to finish a Ziroli P-40 minus the engine and there is not much difference in price: (Note: All prices were obtained from the Ziroli web site and The Aeroplane Works web site) 1. PACKAGE: Fuselage, Cowl, Belly Pan, LG Fairings, Side Windows, Canopy & Plan -- $314 2. 6.5in Aluminum Spinner with Machined Back Plate -- $60 3. Tail Wheel #160WC (Pneumatic) -- $119.25 4. Robart Retracts #150HD8 -- $365 5. 157VRX Large Scale Air Kit W/Tank and Quick Disconnects -- $76.95 6. 5.5in, 10 spoke, Tuff Treads by Robart {#13855A2 (each)} $72 x 2 = $144 7. Wing Kit (The Aeroplane Works) -- $275 Total = $1354.20 So basically, for less than fifty dollars Yellow Aircraft does most of the work for you and details the fuse with accurate scale panel lines. Not a bad value. [/QUOTE] Yea...except I cut my own wing so I would end up saving that amount but you're basically right....Ziroli is a bit bigger, as well..
