KS, USA Status: offline
I am know this radio pretty well, and saw there are several others that use this combo, There are many questions regarding setup on these tx's in these forums, lets share our thoughts, setups, and reasons behind our setups, to learn more about our equipment!
< Message edited by acebusa -- 12/8/2006 2:36:58 PM >
I guess I will start the questions, Does anyone know if there is a better battery for the tx? The stock ones seem to suck, mine only last for about an hour. after charging all day, and night.
ON, CANADA Status: offline
The VR mod is a good one as HH said, and easy to do, your stock battery will work for up to 3 times longer with this 15 dollar mod. And before I knew about that one, I stuffed an 8-cell AA NiMh 2200mAh pack into the compartment, it runs all day with the stock regulator. DO NOT keep flying after the battery warning has gone off. Land immediately, or you will crash very soon. You can even use one of your spare BCPP 11.1v LiPos, just remove it for charging.
_____________________________
The helicopter is the only flying machine ever invented capable of crashing into _itself_.
AK, USA Status: offline
has anyone took the clicker out of the back? i flipped it over so it doesnt click and to add some resistance. the problem is that it is ery very senstive. any ideas?
AR, USA Status: offline
quote:
ORIGINAL: the dog
yes the throttle. there isnt much resistance obvioulsly. my dx7 has a adjustment screw but the 6 unfortunatley does not. i was hoping someone had a fix for it.
I did the same mod on my DX-6 I just flipped over the tab, Like you did, but had to take it off and bend it, to put more restriction on the stick, until it had enough resistance, I love the feel of mine now.
I havent open up my DX6 yet but with my efite radio I flipped the tab over and its a little loose. Others simply slide a piece of fuel tubing over the tab. Apparently it takes away the ratchet and adds just the right amount of drag. Dont know if it creates rubber dust after a while.
OH, USA Status: offline
i just got the ratchet out of my 9CAPS the other day. all i did was take the back cover off (careful!!! if you have a 9CAP/S, there are two wires that are very tight to the back panel!!!) and put a really heavy piece of fuel tubing (approx 1" long) over the metal piece. before you put the fuel tubing on, add some lithium grease or something to it. BEFORE you put the back on, feel the throttle, and make sure you got the ratchet out (bigger fuel tubing if not) and you like the feel (bend tab if necessary. my tab didnt need bent, and it added a VERY nice feel to the throttle.
< Message edited by thermlin -- 12/11/2006 10:58:04 PM >
Any more thoughts on the dx6? maybe post some settings, just out of curiosity what is the expo? Maybe some thoughts on pitch, and throttle curve points also. Normal and Idle up. Thanks in advance!
The instructions for the DX6 dont seem to explain what the ccpm mix value does. You can set the value for each of the three channels CP2,CP3,CP6. The default is +60%. Anyone know what this does?
