has anyone used the walkera 64c
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> has anyone used the walkera 64c
Page: [1]
Login
has anyone used the walkera 64c - 12/9/2006 1:53:32 AM
xchrisx
Status: offline
b/c i have been looking at it and wanted to know what everyone thinks of it good or bad
       Post #: 1
RE: has anyone used the walkera 64c - 12/11/2006 2:22:07 AM
xchrisx
Status: offline
ANYONE????
(in reply to xchrisx)
       Post #: 2
RE: has anyone used the walkera 64c - 1/8/2007 10:09:33 PM
youflynow
Status: offline
I will have them in, in a couple of days. I will post my opinion once they are received.
       Post #: 3
RE: has anyone used the walkera 64c - 1/11/2007 12:38:39 AM
youflynow
Status: offline
It official…this is one of my new favorite Helis’. This thing is tiny and a little unstable at first, but after setting the trims and insuring everything is balanced, it flies well.
If you are used to flying stable helis’, like Trex or one of the bigger Walkera’s, it will take some getting used to.
As a RTF Micro Heli, it delivers as promised.
I’ll see if I can get a video going on youtube. The one on there now does it no justice.
(in reply to youflynow)
       Post #: 4
RE: has anyone used the walkera 64c - 5/16/2008 10:30:55 PM
maddenjoe
Status: offline
I would appreciate some advice on setting up the heli (64C) for first hover flights. What should the settings(throttle, Pit etc) be ? What should the GYRO (WK-G008) settings be ?
Regards,
Joe
       Post #: 5
RE: has anyone used the walkera 64c - 5/16/2008 10:49:36 PM
salat
Status: offline
please do search on rcgroups for "Wlakera" exactly as typed (misspelled). there is a thread about it which is relatively alive
Kostya
_____________________________
Kostya
(in reply to maddenjoe)
       Post #: 6
RE: has anyone used the walkera 64c - 5/17/2008 5:12:17 AM
cflytrap
Status: offline
I just got a 64c last month, after setup it flies really nice. I like it alot. There are very very few parts available in the US. I order from a guy in Australia he ges it to me in 4 days in NW united states.
It is a really cool helicopter, but you must be very patient with it.
Might as well face it, I''m addicted to Hubs.
(in reply to salat)
       Post #: 7
RE: has anyone used the walkera 64c - 5/18/2008 12:48:45 PM
maddenjoe
Status: offline
Nice to know model flies OK. I am setting up the 64C for its maiden flight - can you advise on the settings you used (Pit,throttle, gyro,.....). Instruction booklet has me a bit confused re these basic settings and also re the setup gyro settings.
(in reply to cflytrap)
       Post #: 8
RE: has anyone used the walkera 64c - 5/20/2008 4:53:05 AM
cflytrap
Status: offline
First thing is unplug your motor, and turn on your TX.
Ok assuming the helicopter swashplate and head linkages are setup correctly, and your transmitter is zeroed out, your should have 0-2% positive pitch at 50% throttle ideally depending on your flying style.
to adjust pitch turn on the #10 DIP on the back of the TX. this unlocks v1 and v2 and allows you to influence your collective pitch. v2 is your overall collective pitch adjustment. if you turn this to the right + the overall up and down range of motion becomes greater, which will make your model more agressive. decreasing tv2 shortens the amount the collective pitch travels and makes the copter more docile. v1 is the throttle curve and in my opinion is tricky tricky. If it is at zero, the throttle will respond proportianally and equally with your throttle inputs on the tx. if you go into the - the model will have its blades pitched earlier when you throttle up. If it is into the + it will gain more headspeed before the blades get pitched.
I never mess with the gyro. set the rudder extent to what it needs to be and turn the sensitivity to about 75%. Do nothing thru the Tx.
V!
       Post #: 9
RE: has anyone used the walkera 64c - 5/20/2008 5:03:44 AM
cflytrap
Status: offline
have u seen kostya's video. i bet that guy could teach both of us a thing or two about proper setup.
       Post #: 10
RE: has anyone used the walkera 64c - 5/24/2008 12:10:34 AM
maddenjoe
Status: offline
Thanks for the advice, Salem
Joe
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
