RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!! Page: <<   < prev  143 144 [145] 146 147 148 149 150 151 152   next >   >>
Login
RE: OFFICIAL Team Losi Micr... - 6/26/2008 2:46:26 AM
HandicappMan111
Status: offline
i had one blow on me but it was a losi pack, losi refunded me of everything i had on the car. I talked about it a few pages back i think. But lipo's are a huge performance plus! once u go lipo u wont go back to nimh
(in reply to madmax22)
       Post #: 3601
RE: OFFICIAL Team Losi Micr... - 6/26/2008 3:55:04 AM
LBRC
Status: offline
Trash, the Li-Ions can't delivery enough current and a Li-Ions internal poly fuse is a pain cutting in whenever the cells get hot which is often with the high current Micro-T motor, even worse than the unimpressive Losi LiPo and it's LVC that cuts in every time the cells try to deliver more current than they have available which is why they tend to stall all the time. A brushed Micro-T motor can draw over 2 amps so what you want to look for is a 10C or better current rating. For example the Aero-nuts pack has a 12C rating so 12C x 200mAh = 2.4 amps of continuous current delivery.
The best I’ve found that fit was a 12C 250mAh pack for a Micron FP helicopter, unfortunately it was discontinued and consequently so where it’s LiPo’s.
< Message edited by Reiko -- 6/30/2008 7:27:32 PM >
(in reply to sch1tz0fr3nik)
       Post #: 3602
RE: OFFICIAL Team Losi Mic... - 6/26/2008 4:30:50 AM
sch1tz0fr3nik
Status: offline
Handi - Ahh ya, I remember reading about that Heh, Read through this whole thread once I picked up the Micros. Lots of good info, but ALOT of the same thing about Lipos...
LBRC - Thanks for the Info...saw maybe 1 or 2 posts in the entire thread about the Li-On batteries, and it wasent much info. I may check out that Aero Lipo that has been talked about recently.
My lipo Experiance is 0, So thats what has gotten me a little worried about the Cons of Li-po battries
(in reply to LBRC)
       Post #: 3603
RE: OFFICIAL Team Losi Mic... - 6/26/2008 5:37:41 AM
LBRC
Status: offline
Lipo’s are great just never leave them un-attended, always remember to unplug them when not in use, and toss them if they ever get puffy (pillow like). I have a couple of the Aero-nuts packs, they work great even if they are a bit of a tight squeeze but the price is certainly right. Too bad they don’t come with a Micro-T connector and the wires are a bit stiff and large, I replaced the wires in mine with some terrific low resistance thin wall silicone Doctor Motor slot-car motor wire, removing the balancing plug and wires but attaching a small thin and flexible balancing wire so that I can balance the cells if needed.
Since I mentioned balancing I suppose it deserves a bit of explanation; a 7.4v 2s LiPo has two 3.7v cells connected in series occasionally the two cells can become unbalanced, meaning one has a higher voltage/current level than the other, bad when charging and bad when discharging. Charging since LiPo’s charge to 4.2 volts per cell so 8.4 volts for a 2s pack that means with an unballanced pack one cell is being overcharged while one is not receiving a full charge, then when discharging the reverse happens so that the not fully charged cell can be discharged bellow a safe 3 volts per cell. 2 x bad and it can get worse during every charge/discharge cycle, especially if you don’t remove your pack from the car when charging and never notice the danger signs i.e. a hot or after it’s too late puffy/pillow like pack. Ideally a good pack will never become unbalanced but s*** happens, so with a third wire at the + to – connection you can monitor the pack by reading the voltage across each cell and charge them separately or in the case of a balancing charger/adapter as a parallel pack.
Not necessarily cheep but I highly recommend investing in a good charger with a voltage display and internal safety circuitry from a mainstream hobby supplier, and by that I mean a multi-battery type computerized charger like the Intellipeak Ice or Triton, not even any of the Ice or Triton knockoffs, and then of course to read the directions. Unfortunately at around $125 they tend to be a bit of an investment but if you stay interested in RC they pay for themselves in the long run. Or at the very least get a small digital multimeter but prefferably both.
       Post #: 3604
RE: OFFICIAL Team Losi Mic... - 6/26/2008 11:15:02 AM
GAU-8
Status: offline
anyone got a pic or a link of where specifically the antenna goes into the board? i was taking off the body, and accidentally snagged the antenna. now i dont know where to solder it back on, to the board.
EDIT: nevermind, found it
GAAAAAAARRRRGH! within 10 minutes of playing around after fixin it....the black lead wire for the battery lost its connection to the board. sigh, i cant get soldering down to an art yet..and i wont even try getting into that tiny area. ..i can see "attack of the killer.....solder BLOB" all over, it if i try to fix it :P
< Message edited by GAU-8 -- 6/26/2008 12:33:37 PM >
(in reply to LBRC)
       Post #: 3605
RE: OFFICIAL Team Losi Mic... - 6/26/2008 3:55:02 PM
madmax22
Status: offline
lol just send the ESC back to horizon. they still need to send me 4 of them back......
_____________________________
They call me "butthead".......
(in reply to GAU-8)
       Post #: 3606
RE: OFFICIAL Team Losi Mic... - 6/26/2008 8:45:14 PM
Racing T
Status: offline
Handi nice pic!!! did it catch it?? LOL
       Post #: 3607
RE: OFFICIAL Team Losi Mic... - 6/26/2008 8:52:33 PM
madmax22
Status: offline
wooohooo i get 2 back and 4 new DT wheels and tires! i sent them 1 dt wheels/tire b/c it was stripped new shoes for her! yea man!
(in reply to Racing T)
       Post #: 3608
RE: OFFICIAL Team Losi Mic... - 6/27/2008 12:32:04 AM
HandicappMan111
Status: offline
quote:
ORIGINAL: Racing T
haha, ya a few times. it would run up to it and almost like kiss it or something. I think ther going through that spring time heat ya know! haha. guess it thought it was one of them. but it was fun!
Unfortantly theres been horrible rain here. its washed away what was left of my track out back which sucks.
Also! if anyone is looking for a sick dt with lots of extras email me, im really looking for trading it for a rtr nitro rustler or sport.
       Post #: 3609
RE: OFFICIAL Team Losi Mic... - 6/30/2008 5:06:37 AM
sch1tz0fr3nik
Status: offline
So I just ordered the Aero Nuts Lipos based on the good things i've heard recently here. Got one of the chargers also.
Now i was hearing about an LVC that would be recommended. Can anyone point me in a direction for those, or provide examples of what exactly to look for?
Ah and alittle picture of my Fleet while i'm at it:
< Message edited by sch1tz0fr3nik -- 6/30/2008 5:08:40 AM >
(in reply to HandicappMan111)
       Post #: 3610
RE: OFFICIAL Team Losi Mic... - 6/30/2008 12:32:15 PM
GAU-8
Status: offline
INTEGY PRODUCTS for MICRO-T
i havent seen anything here about them here, but i just got a set of aluminum slipper clutch plates.. not sure if anyone is aware about them or not. cause i dont see em on atomics mods or other places..but i could have missed them on other sites/postings
anyways here is the page for micro-t. several choices of spur gear sizes and such, plus a few other things i havent seen.
http://www.integy.com/cgi-bin/webc.cgi/st_sresults.html
       Post #: 3611
RE: OFFICIAL Team Losi Mic... - 6/30/2008 3:17:09 PM
madmax22
Status: offline
dont buy integy...... i had some stuff on my t-maxx and it SUCKED!!!!!! the worst alum. i have ever had, cheap, bent easy.... the only good thing was it looked good....
(in reply to GAU-8)
