Capt Jim
FL, USA Status: offline
Both Omega, and Cool Power are excellent fuels, both are widely used, and both have been well respected over decades of continuous use. There are some diferences though, and there is where you make a choice. One is tinted PINK, and the other is tinted GREEN....which one do you like? Kidding aside....there are a few minor reasons to go with one or the other. Cool Power, the green one, is a synthetic oil based fuel, and although the synthetic oil is actually more slippery than castor oil, it has a lower flash point. That simply means that if the motor runs quite a bit too hot, (the dreaded lean run) the synthetic can burn off and no longer be there as a lubricant. That's a bit of a downside, but on the other hand, synthetics tend to not crystalize on the exterior of the motor and muffler, so they keep the machine looking better. Omega, the pink one, is a castor oil based fuel, and castor oil has been the motor lubricant of choice for ages...long before synthetics came on the scene. It is an excellent lubricant, and because it has a higher flash point, it will hang in there, doing its job of lubricating, at higher operating temperatures (there's that dreaded lean run again) than the synthetic can withstand You get a bit of lean run protection with a castor oil based fuel, but the price you pay for that extra protection from castor is that it tends to crystalize on the exterior of your motor and muffler, and that just doesn't look pretty. It will leave a dark stain on the piston and liner too, but that stain is still acting as a lubricant. Pretty neat stuff, eh? Castor is also a very fine after run oil too. So, which one do you choose? Well...do you like pink, or green?
_____________________________
Captain Jim
