itchycods
TX, USA Status: offline
quote:
ORIGINAL: FDuce quote:
ORIGINAL: itchycods FDuce, what kind of connectors are on your batteries, and what are the measurements? They have the Tamiya style connector, so I would have to get the adapters. They measure 5.25" long X 2" wide X 1" high. They would be at the very bottom of the range of voltage for this plane. I use two electrifly 7.4v lipo batteries, so together they work fine. I'm not sure if they would have enough "oomph", plus the C-rating might not be high enough to supply this motor without overheating... Do you know what the rating is?
