spacestout
Mr Crash test, I've wondered if you have any trouble with 5 cells. As you know, setting up a plane's propulsion involves knowing the motor max and surge currents, same as for the ESC. However, Electristar provides none of this information. I found, in reading the specs on my Real Flight flight simulator that the motor is a Electrifly Rimfire outrunner 42-60-600. You can read about it here, http://www.electrifly.com/motors/motors-rimfire-42-60.html. It allows up to 25V. You are probably driving it at 21V full charge. The ESC in this plane is the SS-45D, rated at 3-4 cells, 45A max, 50 surge. http://www.electrifly.com/escs/silverseries.html. So, with your 5 cell setup, you are technically safe with the motor, but have more cells than recommended for the ESC. If you fly with the standard 11x7 prop, you may have trouble getting over 30A, as I found in Utah at 4300'. I like your approach of 5 cells. It's a good way to increase power. I wonder if you have ever put a power meter inline to see how much current you draw at full throttle? If you are staying at 45 or 50 and under it might be a good way to go. Can you tell my your prop size, make, elevation and current? I'm running 4200mAh batteries with an APC 13xwhatever prop and come in at about 45A. I'm glad LiPos are coming down. I haven't flown for a couple of years after taking a bullet in the knee in Iraq. My current thunder powers are degrading with disuse. We can expect them to keep coming down as there is a lot of research on them for electric cars. I was given an extra fuse and wings for the 'star. I'm thinking of making the wings straight across (of course they won't be symmetrical) and using either the stock motor (heck, the A on it is 60-70A and up to 14" prop) and a larger ESC and seeing if it will fly more 3D. May fair the wheels. Anyway, I like what you and DBC are doing.
