lejongleur -> RE: Hobbico Electristar Select EP Trainer RTF (1/30/2010 10:38 PM)
I got a request to give some info about the upgrade to a Power 32 Eflite motor. I flew the stock motor setup with a wattmeter onboard and it measured 465 watts peak, using a 3700 mah 4S kipo and an 11x7 prop as prescribed. As the plane weighed in at 88 ounces, this is not stellar performance, but flies OK. As I had a couple of motors lying around, I put in a Power 32. I re-drilled the X-Mount to match the firewall blind nuts, and used alloy spacers to move the motor forward for two reasons: to get the cg further forward when using a 3700 mah 4S lipo (say 13 ounces), as I find my Electristar seems to always glide long, and climbs under power a lot, and the second reason was to allow use of a regular 5mm collet prop adapter. I stuck with the 11x7 after trying other props - 12 inches seems to be the maximum diameter before you run the danger of prop strikes, unless you installed taller nose gear. I've used "Mystery" ESCs - both 60A and 80A, without any problems. This gives a power rating around 800 watts, and noticeably better performance. I got hold of a spare wing, fixed it up including installing two hard mounting points about halfway out, so that I can mount cameras (or rockets!). I haven't got much good video - trouble is, you need to shoot several hours of other planes following you or crossing your path before you get many shots worth keeping. Anyway, this setup works OK with two Flip video cameras on the wings and another camera under the belly on the battery hatch, even though they must create quite a drag. Cameras seem to be getting smaller, better and cheaper all the time so I may try some others at a later date. I also have an AXI 4120/18 which I may install, as the Power 32 now has noisy bearings. The AXI weighs 2.5 ounces more than the Power 32, and as it's kv is 515, it really needs a 14 inch prop, so I will have to find tall nose gear. If I run it with a 5S I should think it will lift a lawn chair if I need to, otherwise it will probably provide similar power to the Power 32 on 4S, as max current is 55A. With three cameras, the AXI, and a 5S 3000mah battery, I expect the AUW would be a bit over 100 ounces, which I believe is the Electristar's original design weight, using the NIMH batteries it was intended for. Hope this is useful!...Chris
