spacestout -> RE: Hobbico Electristar Select EP Trainer RTF (3/23/2007 8:24 AM)
Hobbico was good in support of the ESC problem. We communicated via email first, then on the phone. I'm an electrical engineer, so I was pretty thorough in trouble shooting it. They had me mail back the ESC and wanted the motor as well. I tested the motor with an 11.1 LiPo (I can't find any info on the motor, but I found one under another brand which may be the same thing and it said it would work on 10-20 volts) and standard ESC and it worked so I just sent in the ESC. They apparently couldn't find a problem, but like I said, the new replacement worked. I know there are a lot of worries about the LiPos. I spent the extra money to have them for the performance. I dropped one, sparked another, and even drained one completely while cycling. All no nos (I'm not that dumb. We had a family emergency). I charge them outside in an ammo can. They both came back to life and balance well and charge fully and give me the 4000mAh, so I started to fly with them and they perform perfectly. Not to say their life isn't shortened. We'll see. If you go NiMH you may want a charger which can also do LiPos (like my Multiplex). Then if you upgrade you won't have to buy a separate charger. As far as flight time, I get 15 minutes when easy on the throttle with the 4200mAh Lipos. They are barely warm when landing. The motor isn't drawing much current relative to the 63A the batteries can source. I'd read the reviews on the plane to get the NiMH flight time. Greg on this forum writes a good article, and googling (or use a fun search engine, searchurchin.com) on electristar and review will give you other writeups. The plane is great. Absolutely the best trainer you could want. I got tired of crashing a funny park and Hobbico Cessna 182 trying to learn how to fly. There is almost always a breeze or more. I had a club mentor take up my Electristar on it's maiden. It was windy but the plane flew stabily. I've been flying solo ever since. I love how it flares and greases the landings, and when I err and bounce, it takes it. My only complaints center around wanting more information on the motor specs (to know how much current it can handle) and wishing you could program cutoff levels into the ESC. I believe it lets the batteries drop to 67% which is under the 3V per cell best for LiPos. But, even on the phone with support they say that information is not available. I guess it's a trainer plane and they figure we don't want to do any of our own setting up. I'm flying mine more as a sport plane now. Nice loops, rolls, barrel rolls, stall turns, upside down flight. I can't hold knife edge yet. I want more thrust for high angle slow flight (as much of a Harrier as possible). Remember the flight simulator can have a dual rate switch. Although the 4EXA radio with the plane doesn't have such a switch, if you're on low rate on the sim it will perform more sluggishly.
