spacestout -> RE: Hobbico Electristar Select EP Trainer RTF (6/4/2007 9:44 AM)
screendoor, cwharper has been doing some neat things with his electristar and has a lot of good advice. You have to remember that the batteries have 3 important parameters; voltage, capacity, and current delivery or C rating (how much current can be sourced all at once). I believe the recommended NiMH batteries are 3200mAH batteries at 20C. This means they can source 20X3.2A or 64 Amps. If your batteries are 1500mAH at 20C, that would be 30 Amps and may not be enough poop to power the ESC and motor. Furthermore, it is possible that you batteries are not 20C. They are typically more expensive. You'll see a lot of batteries at 10C or 13C. Either way, this could explain why you can't run full throttle or for very long. You need to have the voltage to push the current (7 seems fine with two in series), you need to have the capacity, and then the source capability to get the capacity as fast as you need it. I have two 2-cell Lipo batteries. Connected in series gives me 14.8 volts (or 16.8 charged). Our motor needs between 10-20 volts. They are 4200mAh batteries but 15C (1C being 4200) So, 4200X15=63A. So, you can use a lower C rating if your capacity is higher. I love the LiPo batteries. They shave a lb off the weight, but were 4 times the cost. So, it you want to stay with the NiMH, go back to the dealer and get the ones recommended in the manual, the 3200s at 20C. You'll notice that the BEC (battery eliminator circuit) 3-wire harness coming from the ESC to the receiver has one wire lifted up. That disables the BEC. The manufacturer thinks that the motor needs all of the current, so you need to charge the 4-cell NiMH pack in the plane and connect it to "battery" on the receiver. That powers the servos. The 600mAh batteries give you 3-4 flights before you need to check the voltage (at 4.8V you better be recharging, I think). I replaced my 600 with a 1500. I also replaced my xmitter 600mAh battery with a 2500mAh pack. Radio doesn't go dead so fast. A caution. You will be powering up the ESC when connecting the motor batteries and arming with throttle position. You will also be switching on (switch on the side of the bird) the servo/receiver battery. After flying, you may shut off the receiver battery. If you haven't disconnected the motor battery, switching back on the receiver leaves you with a live motor. You don't have to rearm the ESC. So, take caution to always disconnect the motor battery first thing. And finally, the manual says that the ESC cuts power to the motor when the batteries reach something like 70% of their charge. Thus, if you connect a partially charged battery, the ESC will think that that is its max voltage. So, connect a fully charged, proper capacity battery and she'll fly like a champ. Know how long your motor runs with a mixture of full and half throttle. Then, time your flights and land with charge to spare (dead sticks are hard and don't leave room for a go-around).
