Jimbonator
ME, USA Status: offline
Hi all! Ive been trolling for a while, reading up as much as I can. I finally ordered an Eagle 50. Once I got it, before I even fired it up, I checked the swash for level, removed the label from the motor, balanced (still a little tail heavy), turned the battery, and straightened the flybar paddles. Once that was all set, I turned on the TX, plugged in the batteries (no motors) & checked the servos to make sure everything was fine, which it mostly was. Un-plugged the battery, connected the motors plugged the battery back in & fired her up slowly. Blades seemed to be tracking fine, had to adjust the the tail trim tab to get it to move once I started adding throttle, but thats all good. The problem I see, and it may be minor, is that when I push the control stick left, it it tilts the swash lower than it does when I push the control stick to the right.....any ideas? Thanks, James
_____________________________
I do my best aerobatics when I''''m trying to stop it from crashing. - tommis85
