RE: sport jet scratch build
Tower Hobbies
Logged in as Guest
  Printable Version
The JETLEGEND L-39 (3 COLOR SCHEMES) We now offer building & Special Paint scheme
Seller:  FlyingboyD
Details:   $2,600.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: sport jet scratch build
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: sport jet scratch build - 12/13/2006 3:14:16 PM
Bob R2
Status: offline
Next is assembly of the composite shells to the frame. Hysol (what a great invention) is applied to the formers and longerons. The right and left shells are held in place with masking tape and clothes pins. After cure, the top surface is taken down flat to the basswood longerons with carving knife and sandpaper, and a cap is glued to the top of the boom structure. The top surface is shaped to the desired contours. A flat floor for the fin is carved into the top surface, and the holes for rudder servo lead and fin spar box are cut.
When the outer surface is ultimately glassed, the structure will be a glass/balsa/glass sandwich with c/f reinforcement. Very strong and very rigid. A modern (sort of) composite structure with old school construction methods.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Bob R2)
       Post #: 26
RE: sport jet scratch build - 12/13/2006 4:10:03 PM
mick15
Status: offline
Hi bobber
I did a scratch sport jet if you are interested, didn't want to hijack the thread
M
       Post #: 27
RE: sport jet scratch build - 12/13/2006 4:18:02 PM
Bob R2
Status: offline
Thanks Mick, I'd like to take a look later today. If it is not on RCU, I'd appreciate a link.
Bob R
(in reply to mick15)
       Post #: 28
RE: sport jet scratch build - 12/13/2006 4:39:26 PM
Bobman
Status: online
Bob,
Nice job! Unfortunately scratchbuilding is becoming a lost art form.
An off topic question.... can you give me some details on your building table? I'm in process of building my new shop and am looking for ideas on a moveable table like yours. My concern is keeping it flat when moved, or at least keeping the adjustments to a minimum. I've used hollow core doors mounted stationary on frames with good success for years, but would prefer something larger & one piece (4x8) that I could move around the shop when required.
Thanks!
Bob K.
_____________________________
Jet Black R/C Models www.JetBlackRC.com
Authorized SkyMaster ARF-Plus Dealer /Jetcat Dealer
       Post #: 29
RE: sport jet scratch build - 12/13/2006 11:52:40 PM
Bob R2
Status: offline
Hey Bob,
That table is just a piece of mdf flopped on top of my Jet cabinet saw and extension. The end over the saw is very flat, but the opposite end over the extension is not. I have another bench, which is fixed, with a glass top that is shimmed to flat.
Bob R
(in reply to Bobman)
       Post #: 30
RE: sport jet scratch build - 12/14/2006 4:20:10 PM
Bob R2
Status: offline
The fin is traditional built up construction with some c/f on the spar.
Click for fullsize
Click for fullsize
       Post #: 31
RE: sport jet scratch build - 12/16/2006 12:53:18 AM
Bob R2
Status: offline
A few pics of the components blocked up. I'm far enough along with the build that I can now imagine jet noises to keep my motivation up.
This will be my last post for a while. The holidays and a work project will slow things down a bit.
Have a good holiday,
Bob R
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 32
RE: sport jet scratch build - 12/16/2006 9:33:27 AM
john agnew
Status: offline
Bob
Congrats. on a great looking model, very quick work too! Your workshop looks a bit underequipped though, I think you need some bigger machines!
John
       Post #: 33
RE: sport jet scratch build - 12/16/2006 3:31:06 PM
Bob R2
Status: offline
Thanks John. Actual build time has been more like four weeks scattered over a couple of months, so not nearly as quick as the pics would imply.
(in reply to john agnew)
       Post #: 34
RE: sport jet scratch build - 1/3/2007 11:31:53 PM
Bob R2
Status: offline
I was able to make a little more progress over the long weekend.
Next up is the pod portion of the fuselage which will be built clamshell fashion. Right and left side temporary formers are glued to a piece of scrap aluminum laying around the shop. The side and bottom pieces are cut from sheet balsa and the inside surfaces are laminated with glass or c/f. The side and bottom pieces are then glued to the temporary formers. Finally, balsa strip planking is applied to the portions of the pod with compound curvature.
I hope my wife doesn't hear that I've been on line talking about "strip planking".
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 35
RE: sport jet scratch build - 1/3/2007 11:39:02 PM
Bob R2
Status: offline
The right and left sides are rough sanded and trimmed, then they are popped off the aluminum backbone. The temporary formers will be removed and a bit more glassing will be done on the inside surfaces. Once the clamshell halves are glued together, the outside surfaces will be glassed. This will produce a glass/balsa/glass sandwich shell with c/f reinforcement.
Time to fire up the lathe and turn a foam nose piece.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 36
RE: sport jet scratch build - 1/4/2007 3:40:35 AM
Boomerang1
Status: offline
Looking good Bob, a bit more shapely than mine. Yours is looking like a Jaguar, mine a bit like a Volvo!
A friend has a P-70 in a Boomerang, sweet engine. It replaced a Jet Joe, now that left a bitter taste in his mouth! - John.
Distributor for: Nothing! So my posts can be unbiased.
       Post #: 37
RE: sport jet scratch build - 1/4/2007 2:08:34 PM
Bob R2
Status: offline
Thanks John. The P70 was previously in my 23 lb BobCat Comp and pushed it around OK, so it should do OK in this airframe. I was hoping to keep things light enough that I would have a 1:1 thrust to weight ratio, but that ain't going to happen. If the plane survives the test flights and the vertical performance isn't up to expectations, I may consider a motor swap - perhaps a Falcon.
(in reply to Boomerang1)
       Post #: 38
RE: sport jet scratch build - 1/5/2007 2:04:15 AM
Bob R2
Status: offline
Foam blocks are glued up around a central shaft, then chucked up in the lathe. After a few minutes with various cutting tools and a few sanding blocks, the nose takes shape. A check fit on the fuselage shows a decent transition of contours, but a bit of tweaking of the nose shape is needed. Ultimately, the foam block will be glued on, glassed, then dissolved out with lacquer thinner.
Click for fullsize
Click for fullsize
Click for fullsize
