RE: sport jet scratch build
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld BAe Hawk - RTF
Seller:  rambat1
Details:   $17,500.00   |  8/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: sport jet scratch build
Page: <<   < prev  1 2 3 4 [5]
Login
RE: sport jet scratch build - 9/19/2007 7:35:24 AM
GrayUK
Status: offline
Fantastic project, beautiful painting..
Well done...now where are the kits?
Paul
_____________________________
All the knowledge in the world, is of no use to fools.
(in reply to Bob R2)
       Post #: 101
RE: sport jet scratch build - 10/7/2007 4:58:49 PM
Bob R2
Status: offline
Reinstall complete, back to the field. It has been a while since the last flight, so it was a bit like a new maiden flight. Joel was there to make sure I didn't screw things up too badly. All the previous settings and trims were good, and it is still a ton of fun to fly. Visibility is much improved, and the yellow/red scheme is easy for me to see.
Thanks to the Sequin gang for support along the way, and thanks to everyone for following the thread and posting kind comments.
For those scratch builders out there, I'll post the numbers for the plane below.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to GrayUK)
       Post #: 102
RE: sport jet scratch build - 10/7/2007 5:18:21 PM
Bob R2
Status: offline
I'm very pleased with the performance of the plane. The numbers for the design are "plane vanilla", which is probably the reason it performs well. The biggest unknown for me was the engine mounting and ducting design. However, the airframe stays quite cool (even with the 120 size motor), the motor seems to be getting adequate air, and drag isn't too bad judging from the speed of the airframe. The only thing I'd change in the design is to adjust the stab incidence slightly because it originally took 5 clicks of up trim for straight and level flight.
I know I like to scavenge for design data from other builders, so I thought I'd post it here for those who are interested in this kind of arcane stuff.
Length: 71 in.
Wingspan: 62 in.
Wing area: 900 in. sq.
Wing dihedral: 2.0 degrees
Wing washout: 1.5 degrees
Stab anhedral: -12.0 degrees
Wing and stab airfoil: NACA 0012
Incidences:
Fuse bottom: 0.0 degrees
Wing @ root: +1.3 degrees
Stab @ root: +.75 degrees (too much, should probably be about .5 degrees)
Motor downthrust angle: 9.0 degrees
Flap angle deployed: 33 degrees
CG: 25% MAC with full UAT
Main landing gear placement: 1.6" behind cg
The attached image is very close to the final configuration.
Once again, thanks to everyone for the support and kind comments.
Regards,
Bob
Click for fullsize
       Post #: 103
RE: sport jet scratch build - 10/7/2007 5:23:20 PM
Woketman
Status: offline
Did you ever give it a name? If not, you really need to. It is unbelievable gorgeous. You are a craftsman (not a Sears tool!).
Team Fromeco
       Post #: 104
RE: sport jet scratch build - 10/7/2007 5:49:05 PM
seanreit
Status: offline
Can't wait to see it fly Bob!
(in reply to Woketman)
       Post #: 105
RE: sport jet scratch build - 10/7/2007 8:48:38 PM
Bob R2
Status: offline
Thanks Woketman. I've got no name for it, but I'm sure open to suggestions. Back when the original concept had side ducts and a little F4 styling, I was thinking about Phantasy. However, I lost the ducts to save weight and drag, so there isn't much F4 resemblance any more.
Hey Sean, Tom and I keep threatening to get up to Austin the middle of the week, but so far other stuff keeps interfering. I'll let you know when we are headed up.
< Message edited by Bob R2 -- 10/7/2007 9:33:39 PM >
       Post #: 106
RE: sport jet scratch build - 10/8/2007 2:46:41 AM
JoelP
Status: offline
Bob ought to call his design the "Projectile" because this lil gal scoots! Just my opinion but it out performs the swept fin Balsa Bandit I used to own.
He nailed the design...blistering passes with high g pulls, over and over, with no signs of stress. The jet presents very well in all flight attitudes and landings are a piece of cake.
The new colors are highly visible and the Spektrum link has been absolutely solid.
       Post #: 107
RE: sport jet scratch build - 7/4/2008 8:28:54 AM
Matzito
Status: offline
Dear Bob saw your nice design and at present I´m thinking about building some similar trainer for easy transport, easy flying, easy handing, something for every day flying.
I like the design you.
Do you have any CAD drawings or models I might use?
Best Regards
Matthias
(in reply to JoelP)
       Post #: 108
RE: sport jet scratch build - 7/4/2008 2:44:36 PM
Bob R2
Status: offline
Matthias, I do not have any usable/readable construction drawings. However, I can email you a .dwg file of the image in post #103 if that would be helpful.
Regards,
Bob
(in reply to Matzito)
       Post #: 109
RE: sport jet scratch build - 7/4/2008 3:22:43 PM
cel
Status: offline
Hello Bob. Congratulations, what a gorgeous project. Do you have any video? Could you please send me email ( celso@thagex.com.br )of the DWG file of image in post 103 ? Regards
       Post #: 110
RE: sport jet scratch build - 7/4/2008 5:22:03 PM
Bob R2
Status: offline
Hi Cel. I have 130 flights on this thing, but no video. I really should have one of my fly'n amigos shoot a little footage. I'm leaving for the day, but I'll send you an email tomorrow with a dwg attached.
Regards,
Bob
Click for fullsize
Click for fullsize
(in reply to cel)
       Post #: 111
RE: sport jet scratch build - 7/14/2008 12:20:41 PM
Josh0027
Status: offline
Nice project! Congratulations!
       Post #: 112
RE: sport jet scratch build - 7/14/2008 10:22:06 PM
gooseF22
Status: offline
deleted, disregard
Goose
Team Fromeco
       Post #: 113
RE: sport jet scratch build - 7/14/2008 10:30:39 PM
gooseF22
Status: offline
Is there already a jet called Turbinator? It was the name of the world record holder speed car
Goose
Team Fromeco
(in reply to gooseF22)
