aegis
Joined: 11/30/2003 From: Tempe, AZ, USA Status: offline
I have 10 flights on a plane, and up until today the new 5955 servos worked as expected. However, when doing the ground check prior to the first flight of the day today, I noticed that one of the ailerons would jitter, sometimes, when fully deflected and also sometimes right around center. It doesn't do it all time when moving the stick throughout its full movement. The only control surface doing this is my left aileron, which has two servos. I did a range check to make sure it wasn't interference, and none of the other control surfaces, including the right aileron, exhibit the behavior. For my RX's battery setup, I have two 1950mah 6.0V NiMHs. Each of the batteries is plugged into its own switch, and each switch is plugged into a different RX port. I have to run two aileron servos off a single channel and so am using the MPI Double Link as a wye. I tried connecting only one left aileron servo at a time and moving the TX stick back-and-forth from full left to full right; there is no jittering. That made me think it might be a power delivery problem through the Double Link. So, I tried a different/new Double Link but got the same result. I also tried a HD 20 AWG wye and got the same jittering. (The Double Links and wye have gold plated connectors). I inserted in-line volt meters between the Double Link and servo extensions in order to see if there is significant voltage drop when applying aileron input. The voltage was 6.7V at rest and dropped to 6.65V, on both in-line meters, when moving the stick to full deflections. These were the exact same readings as the right-side aileron, which doesn't jitter at all, when measured through its Double Link. I did the same in-line voltmeter test with the 20 AWG wye instead of the Double Link; the voltage drop with the wye was just slightly more than with the Double Link. So, it doesn't appear the Double Link is the problem. Any ideas why the problem exists only once both left-side aileron servos are connected? Dan
