ROYAL C-47 / DC-3 KIT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Piper J-3 Cub 40 ARF / Saito 90 twin - RTF
Seller:  Hill202
Details:   $450.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> ROYAL C-47 / DC-3 KIT
Page: [1]
Login
ROYAL C-47 / DC-3 KIT - 12/14/2006 4:54 AM
para1911a1
Score: 100
Last Login: 4/28/2013
Status: offline
I am looking for instructions & plans for a Royal C-47. I have one of these plane that is built. I am looking for setup info. control throws, CG location ect.
Hide Signatures
       Post #: 1
RE: ROYAL C-47 / DC-3 KIT - 12/14/2006 5:39 AM
rryman
Score: 100
Last Login: 4/10/2013
Status: offline
Balance Point: 4 3/4" back of the leading edge at the center section.
elevator: Hi rate: 5/8 x 5/8 Lo rate: 1/2 x 1/2
rudder Hi rate: 1 1/2 x 1 1/2 Lo rate: 7/8 x 7/8
ailerons Hi rate: 5/8 x 5/8 Lo rate: 5/16 x 5/16
Flaps: Take off: half flap-1/2" Landing: Full flap: 1"
Mixing: 1/16" up elevator at half flaps and 3/32 at full flaps. This will keep the nose level when you extend the flaps.
I had flaps on mine but rarely used them. It lands nicely without flaps. If you do put them down, and don't have elevator mixing, be careful, is will slow down quickly and stall if you're not careful. I also had rudder/aileron mixing in mine.
It's a great flying plane.
Randy
Hide Signatures
(in reply to para1911a1)
       Post #: 2
RE: ROYAL C-47 / DC-3 KIT - 12/14/2006 5:41 AM
rryman
Score: 100
Status: offline
Scrap that last transmission. I just saw that you have a Royal and not Top Flite. These specs are for the Top Flite. Should've looked closer! I have no experience with the Royal kit.
Randy
Hide Signatures
(in reply to rryman)
       Post #: 3
RE: ROYAL C-47 / DC-3 KIT - 12/14/2006 8:46 PM
jaka
Score: 158
Last Login: 5/21/2013
Status: offline
Hi!
Important throws are elevtor and ailerons ...Side rudder throw is not that important (but use as much as you can), Flaps should not be used on take of when new you are to the airplane.
C of G on my Marutaka (Royal was the US importer) Dc-3 is at factory setting at 14cm from wing leading edge (at the fuselage).
I have approximately 10mm elevator up throw measured at the trailing edge of the elevator. Ailerons the same
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by jaka -- 12/14/2006 8:51 PM >
_____________________________
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 4
RE: ROYAL C-47 / DC-3 KIT - 12/15/2006 5:30 AM
para1911a1
Score: 100
Status: offline
Thank You Very much!!!!! Your plane looks great!!!
Hide Signatures
(in reply to jaka)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.559RCU1
