What fuel do I need
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> What fuel do I need
Page: [1]
Login
What fuel do I need - 12/14/2006 4:17:34 PM
English J3 piper cub
Status: offline
Hi everyone,
Ive just ordered a new engine and dont know which fuel to use in it. The website says that the engines uses fuel (Thunder Tiger
recommends fuel with castor oil). thats all the page says does anyone know which fuel I need to use so I can get some.
Matthew
       Post #: 1
RE: What fuel do I need - 12/14/2006 6:50:29 PM
Sport_Pilot
Status: offline
Do you not have the manual?
(in reply to English J3 piper cub)
       Post #: 2
RE: What fuel do I need - 12/15/2006 1:51:40 PM
Status: offline
No not yet but I want to buy the fuel before it arrives so I can run it in as soon as possible.
Thanks a lot
Matthew
(in reply to Sport_Pilot)
       Post #: 3
RE: What fuel do I need - 12/15/2006 2:10:52 PM
downunder
Status: offline
It depends on what fuels are available in SA but for running in it's preferable to have at least 20% oil (I use 25%) and a fair bit of castor in the mix. Nitro isn't necessary but if you want to use it then I'd suggest 5%.
       Post #: 4
RE: What fuel do I need - 12/15/2006 2:43:23 PM
Status: offline
How do I mix it? PLEASE
newbie
Thanks a lot
Matthew
(in reply to downunder)
       Post #: 5
RE: What fuel do I need - 12/15/2006 5:22:34 PM
Matthew Allen
Status: offline
quote:
ORIGINAL: downunder
That much oil is certainly kind to your engine, but it's not really necessary. Most manufacturers recommend 18% and many people (mostly those who don't care about their warranties ) use less.
Matthew
       Post #: 6
RE: What fuel do I need - 12/15/2006 8:51:33 PM
Sport_Pilot
Status: offline
quote:
ORIGINAL: Matthew Allen
quote:
ORIGINAL: downunder
Matthew
Matthew, thats a plain bearing engine and the extra oil is good insurance during break in. Just in case they are overly tight. I know many modern engines don't usually have this problem, but it still happens now and then.
(in reply to Matthew Allen)
       Post #: 7
RE: What fuel do I need - 12/15/2006 10:26:09 PM
Status: offline
Hi guys,
I check A website and they have 5%/15%and20%. So Ill be going for the 20% but there are three diffrent kinds which should I use for my engine?
They the same brand :Morgan fuel
1 :Cool Power Fuel
2 : Omega Fuel
3 : Sidewinder Fuel
Dont know which to choose from? Would I need to add anything to these fuels and if yes what?
Thanks a lot
Matthew
       Post #: 8
RE: What fuel do I need - 12/16/2006 2:42:20 AM
downunder
Status: offline
That 5/15/20% is nitro content. Cruel Power/Omega has only got 17% oil but at least the Omega has some castor in it. That Sidewinder is a car fuel and it's probably got 10% or less oil and it'll kill your engine.
Out of that lot, the Omega would be your best bet but get a bottle of castor to add to it.
       Post #: 9
RE: What fuel do I need - 12/16/2006 7:34:37 AM
Status: offline
How much castor should I add to it?
Matthew
       Post #: 10
RE: What fuel do I need - 12/16/2006 1:01:08 PM
downunder
Status: offline
If you're aiming for 20% total oil then add 35cc/litre but chances are you'll be buying an American gallon which is about 3.785 litres so add about...ummm...mumble mumble (carry the 2, divide by 6.058 and find the square root of 3)....errr....add 132.5cc of castor. Then do what I do when I'm mixing fuel and add a dash more oil for luck .
       Post #: 11
RE: What fuel do I need - 12/16/2006 5:17:40 PM
Status: offline
What should I mix the fuel in? ANd what type of castor should use? Where do you get yours from the Service station/petrol station?
Thanks a lot
Matthew
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
