Wire Length For Charging
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  6/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Wire Length For Charging
Page: [1]
Login
Wire Length For Charging - 1/27/2003 1:17:37 AM
Cougar-RCU
Status: offline
Can the Charger To the Battery Wire length be to long?
like would 6 feet be a problem? I was just wondering
because I have planes hanging and I wanted not to take them
down to charge.. These would be charged from a Triton Charger.
Could a Longer wire length cause false readings?
Jeff
       Post #: 1
Wire Length For Charging - 1/27/2003 2:11:45 AM
Red Scholefield
Status: offline
Use fairly heavier gauge wire (#18) or better and you should have no problem. If you are charging at home you are probably not using real high rates anyway so you wouldn't have as much problem as you would if your were tryint to charge at the max rate available.
_____________________________
Red S.
AMA 951 Leader Member
(in reply to Cougar-RCU)
       Post #: 2
Wire Length For Charging - 1/27/2003 3:14:53 AM
Rodney
Status: offline
As Red said, as long as you are not charging at a high rate and depending on a peak detection device to cut off the charge, you should be okay.
       Post #: 3
Thanks Guys! - 1/27/2003 3:25:50 AM
Cougar-RCU
Status: offline
       Post #: 4
Wire Length For Charging - 2/8/2003 8:03:56 AM
canesugarrules
Status: offline
What would you guys consider a high rate? Would 1.25c with the Triton set at 10 mv/cell be OK(ni-cd's)? This would also be used at the field to charge from the car battery. Thanks
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.314RCU1
