OS .46 LA (Bad Engine?)
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. FS-120 III Surpass (Pump)
Seller:  RCadmin
Details:   $350.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> OS .46 LA (Bad Engine?)
Page: [1] 2   next >   >>
Login
OS .46 LA (Bad Engine?) - 12/14/2006 8:35:22 PM
Zephirus79
Status: offline
Well im gonna get an OS engine after what I have read and learned about them... Someone told me to make sure I get the ones with ball bearings in them. He said "The non bearinged are not good at dependability (running adjustment wise)".
Now im still flying a trainer and I plan to use this engine on my second plane in the future. Is the LA that much worse than the AX? Its not quite double the price for the AX but it is close... Your Thoughts?
       Post #: 1
RE: OS .46 LA (Bad Engine?) - 12/14/2006 8:44:16 PM
Glen Wearden
Status: offline
The LA's are good engines for the money, and will last a long time, if you take care of them, run them a hair on the rich side, and run fuel with some castor in it. I run Powermaster 10/22 with equal amounts of castor and synthetic. I've had good luck with the LA carb, in fact I get reliable idle and good transition, and have never touched the low speed needle. Glen
(in reply to Zephirus79)
       Post #: 2
RE: OS .46 LA (Bad Engine?) - 12/14/2006 8:50:52 PM
oldvet70
Status: online
I agree the LA's are good engines. I recommend them all the time to new students. If your still in the 1st to 2nd plane stage it will be fine assuming you put it in a suitable plane.
_____________________________
“No person was ever honored for what he received. Honor has been the reward for what he gave.” Calvin Coolidge
       Post #: 3
RE: OS .46 LA (Bad Engine?) - 12/14/2006 8:52:05 PM
Zephirus79
Status: offline
Sounds great. Thanks for the help!
(in reply to oldvet70)
       Post #: 4
RE: OS .46 LA (Bad Engine?) - 12/14/2006 8:56:03 PM
Dr1Driver
Status: offline
All what Glen said is true. The part that can be not "dependable" is the carb settings. In my experience, an air-bleed carb can be a little picky to properly adjust.
On the subject of $$$. Yes, the AX is a lot more expensive. However, you can buy an LA now and an AX later, or buy an AX now and not have to buy another engine when you move to sport planes.
Dr.1
There's a Hun in the sun!
       Post #: 5
RE: OS .46 LA (Bad Engine?) - 12/14/2006 8:59:41 PM
P47 Jug - Al
Status: offline
I have the LA46 in a Tower Fun 51. http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJA64&P=ML No unlimited verticals with this plane though.
It has been one of my most dependable engines - no flame outs this whole summer. For the money it is a good engine and it will last as others have mentioned.
(in reply to Glen Wearden)
       Post #: 6
RE: OS .46 LA (Bad Engine?) - 12/14/2006 9:09:41 PM
opjose
Status: offline
The LA's run reliably, but they are difficult to tune for optimum performance.
The low end mixture is controlled with a bleed carb, as opposed to a needle carb.
It is difficult to adjust beyond certain ranges.
e.g. on mine I can't lean the low end out sufficiently and I've already drilled the bleed hole as much as I dare.
As a result my engine runs overly rich, but it never deadsticks...
The LA .46 gives you ABOUT the performance of a .32 FX type engine. O.S. rates the LA .46 at 1.1-1.2 HP (which is very optimistic!), while they rate their own .46 AX at 1.7 HP.
So the AX will give you more power than the .46 LA.
I foolishly installed a .46 LA into a Seagull Spacewalker II.
The is about 6-7lbs, so it is a bit heavy for a .46 though that is what it calls for.
The Spacewalker was anemic with the LA engine and an 11x6 APC prop.
I swapped it out for the .46 AX, and the plane was transformed.
IMHO pay the difference for the AX engine. You'll be glad you did.
Build em'', fly em'', crash em'' and build more.
       Post #: 7
RE: OS .46 LA (Bad Engine?) - 12/14/2006 9:17:31 PM
Dr1Driver
Status: offline
Just curious...will the LA turn a 10-4 prop at 14,000 on the ground on 10% the way my OS .32 and Webra Speed .32 will? Actually, the Webra unloads like crazy and, judging by sound, turns that prop a LOT more than 14,000 in the air.
Dr.1
(in reply to opjose)
       Post #: 8
RE: OS .46 LA (Bad Engine?) - 12/14/2006 9:45:42 PM
opjose
Status: offline
Frankly I doubt it.
I put the LA .46 into a .30 plane and it does very well on that plane, including good verticals.
I've tach'd it to about 10.5K with an 10x5 prop sitting on the ground.
(in reply to Dr1Driver)
       Post #: 9
RE: OS .46 LA (Bad Engine?) - 12/14/2006 10:24:28 PM
Dr1Driver
Status: offline
Hmmm...I'd expect it to run a LITTLE better, jose. Another good reason for getting the AX.
Dr.1
       Post #: 10
RE: OS .46 LA (Bad Engine?) - 12/14/2006 10:32:57 PM
Hobbsy
Status: offline
I have two LA .46s and a .65, look in the air inlet hole on the front of the carb and set the airbleed screw halfway across that hole. You will be within 3/4 of a turn either way from a great idle, the midrange is controlled by a metering slot in the carb barrel.
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 11
RE: OS .46 LA (Bad Engine?) - 12/14/2006 10:44:36 PM
opjose
Status: offline
That makes mine WAAAY too rich. I have the hole completely uncovered and it's still very rich.... spewing fuel at idle.
I've reamed the hole out a bit to make it a bit larger, but I didn't want to take this any further.
(in reply to Hobbsy)
       Post #: 12
RE: OS .46 LA (Bad Engine?) - 12/14/2006 10:45:55 PM
opjose
Status: offline
Ok, maybe 11K... but then not consistently....
(this is backed off peak about 4 clicks).
       Post #: 13
RE: OS .46 LA (Bad Engine?) - 12/14/2006 11:15:59 PM
Jim C.
Status: offline
I have one that I had on my trainers, and it was a great engine. They are great for starting out in the hobby. Yes, they can be a ***** to tune sometimes. I would recommend them for trainers but not much else. I have a .65 la on my cloud dancer and it does great. of course, I have a k&b 65 nib maybe I should try that one!!
Edited by moderator to remove foul language.
< Message edited by Rcpilet -- 12/15/2006 3:11:54 PM >
http://jimsrc.com
Mulligan Hill RC Club
       Post #: 14
RE: OS .46 LA (Bad Engine?) - 12/15/2006 12:09:36 AM
foresterxt
Status: offline
I also have a 46LA that was my first engine. In my opinion it's a great first engine. You won't notice the lack of power until you're good enough to move to more advanced planes and at that point, it's fun to buy a new engine anyway. When you work you're way through the trainer, throw the 46la on an Uproar 40 arf- an absolute blast! No one at the field believed it had a 46la until I landed.
(in reply to Jim C.)
       Post #: 15
RE: OS .46 LA (Bad Engine?) - 12/15/2006 4:44:55 AM
Ed Cregger
Status: offline
quote:
