reincarnate
IN, USA Status: offline
Ian... Regarding the 6 Volt system the JR 791 will not function past approx 5.4 volts. Sorry can't figure out how to quote a portion of a post. That being said, the above is your reply on the 791's. I've got them hooked up to my 6v system, (still. Haven't decided what to do) just checked my battery (hobbico voltmeter) with Rx load on and read 6.52 volt. The servo's work fine, and have probably cycled them approx 50 times testing, adjusting and just watching them work. I'm getting no buzz, hum, chatter or anything from the servo. I swear I'm not being argumentative, just trying to deal with this issue. If my questions are helping someone else, then it will worth the trouble. I just can't believe I'm the only person with 791's on a 6v system. Hopefully you guys don't think I'm an idiot or a fool. The constantly learning process I go through just makes it seem that way. Bear with me please. And if you believe me, please inform my wife. She thinks I'm an idiot, a fool, and a few things the moderator would edit.
_____________________________
Are the wheels supposed to fall off when you land? No? How about the engine?
