Rip n Bank
CO, USA Status: offline
Captain Ron, LOL! Well, I definitely got one of the "Caution: Some custom, and repair, work required" labeled boxes! Do this please: using the apex of the two dihedral angles, draw a centerline on your spar with a pencil. Check to make sure it's equidistant from the ends. Then, slide the spar all the way into one wing and mark the spar with a pencil where the inside-most rib runs across it. Then, keeping the spar orientation the same (same side forward), slide the spar into the other wing pocket all the way, and scribe the another pencil line for that depth of insertion. Chances are, you have three lines showing. At issue is how far apart the lines are. Now, perfect would be all three lines were pretty much on top of each other, or at least close. If not, then it's likely the spar slid in past the center line in each wing. so, let me know how far apart your outermost lines are. For me, the line for the right wing inside edge was LEFT of the center line, meaning the spar went in too far and, therefore the spar wasn't long enough. Same thing for the left wing. These two outside-most lines were 3/8" apart (3/16" to either side of the center line), which is a lot of missing wood from the length of the spar (and correspondingly, a lot of epoxy fill, which isn't as strong as wood when it comes to occupying this void!). And, like I said, it's also too thin (wiggles a lot front to rear in the pocket) and short in height (wiggles a lot up and down in the pocket). Conclusion: H9 is building the wing spar pockets too big, or making the spar (already fairly short for such a wingspan) too small. Nothing I can't overcome, but I shouldn't have to... Bo quote:
ORIGINAL: captainron RIP N BANK, I FIGURED IT OUT, HANGER 9 SENT OUT ALL THE BAD KITS TO THE GUYS WHO ARE GOOD AT AND WHO DON'T MIND MODIFYING THINGS TO MAKE THEM WORK. THEN, THEY SENT OUT ALL THE GOOD KITS TO GUYS LIKE ME THAT JUST WANT TO BUILD IT FROM THE BOX AND GO FLY EM'. AFTER READING YOUR LAST POST, I RAN OUT AND CHECKED MY WINGS. JOINED THEM FOR A DRY RUN WITH THE SPAR AND THEY SEEMED TO BE OK. BUT, MAYBE MY TOLERANCES ARE A LITTLE LESS STRINGENT THAN YOURS. WEATHER GETING BETTER IN COLORADO, WON'T BE LONG NOW. EXCEPT FOR WEDNESDAY. SHOULD BE A NICE WEEKEND, GO GLY SOMETHING. DANG, I LOVE THIS HOBBY. CAPTAIN RON. quote:
ORIGINAL: Rip n Bank quote:
ORIGINAL: Jarrah Bo, looks great, i am reallly impressed with your access hatch. I was actually going to do something similar but i think ill mount all my switches in the cockpit and then hold that on with magnets ifi can find some sutible ones. Hopefully should start mine with the keleo in the next few days. Thanks, Jarrah. I'm pleased with the way the hatch came out, too! On a different note: I'm curious if anyone ended up with a "too short, too thin" wing spar. I was going to epoxy the wing together the other night and found that the spar was 3/16" short on each end, (3/8" overall). It wasn't thick, or tall, enough either and really rattled around in the wing receiving pockets. I don't feel comfortable making up all that empty space in the pockets with epoxy, so I just finished making a replacement hardwood spar that's 3/8" longer, and a hair bigger in thickness and height. I'm sanding it down carefully to a perfect fit that still has space for a good coating of epoxy on all sides. Much as I love this plane, I have to say that my spar problem, the wing replacement I had to do because they drilled the flap holes too big, and the noticable "undulating" surface of the fuselage and the wing under the ultracoat, that this is the poorest quality H9 plane I've built so far. That won't stop me from lovin' it when I'm ripping down the runway 10' off the deck, but given the price, I'm a bit disappointed with this one... Bo
_____________________________
The more planes you have in your "hangar," the less likely your wife will notice a new one!
