Mustang Exhaust
- Kit
Seller:tony-howard Details:
$35.00
| 7/5/2008
| Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
LA, USA Status: offline
Ask Kevin at Keleo if he can install the P-51 operational exhaust stacks for you. I have a set and I love them.. It is so cool when the 200TI in my plane starts up the smoke barks out the stacks!!
NM, USA Status: offline
I downloaded the manual and it says the engine mount was set up for a Saito 1.80 and "If you plan on using another engine, such as the Saito 2.20, you may need to remove the blind nuts and drill new holes in the firewall for your particular engine." I bought the Evo 35GT and I hope I have the skill to install it.
riotgear - Unfortunately I do not have the plane yet...its gonna be a b-day present in Feb. I was looking at the specs on the Saito-220 and the Evo 35GT and the Evo is 9mm wider on the engine mounting flanges (outside-outside dimension) and shorter in height from top of cylinder to center of crankshaft by about 12mm. (Evo did not supply dimensions from crankshaft to bottom of crankcase.)
Does anyone have the spec.'s on the max. width and height of the firewall?
I hope that the extra ~1cm width doesn't cause mounting problems.
Joined: 11/12/2002 From: Newcastle, WA, USA Status: offline
Pettit, Good looking model you have there, what engine are you using? keep us posted on the first flight results. On another note, I noticed the interesting styro stand you use to support your model - what make is it and where did you get it?
CO, USA Status: online
quote:
ORIGINAL: san26141
The Saito 220 fits as expected, with just the valve covers protruding outside of the cowl, as the Saito 100 does with the smaller H9 60 P-51.
I moved both the port side t-nuts, increasing the spacing to the starboard side t-nuts by ~3/16". Crank still comes out centered (to the 1/16" .
Without the supplied spacers, and with the 220 slid all the way forward on the mount, the prop disk only protruded about 3/32" past the front of the cowl, a bit too close. So, I still used the supplied spacers between the engine mount and the firewall, and slid the engine placement back on the mount's open rails until I achieved the recommended spacing.
After careful examination of the supplied 5" spinner, I decided to dedicate that as the "static display" spinner, with the four scale blades, and will use a Dave Brown or Tru Turn 5" parabolic, finished with self-etching primer and matching yellow paint, for actual flight.
Included a few photos below...
Bo
_____________________________
The more planes you have in your "hangar," the less likely your wife will notice a new one!
IN, USA Status: offline
OK I think I've decided. Going to go with the fuji BT 32EI on mine. W/modified rubber mounts, it should come out length-wise real close to perfect. The only hitch I have is the mounts that the Fuji comes with are too wide to fit inside of the built up part of the fixed cowl. Does anyone have any bright ideas or experience on how to get past this. I know I can't see the forest for the trees, so lend me your chain saw. I'm planning on reinforcing and glassing the firewall but I don't want to cut much of the wood away. Help!
Are the wheels supposed to fall off when you land? No? How about the engine?
