Rip n Bank
CO, USA Status: offline
quote:
ORIGINAL: Jarrah Dad and I are about to buy one of these babies, just unsure of what engine to go with, we are tossing up between a saito 180 or a saito 220, we need to spin a 3 blade prop hopefully in the 17-18" range hence im guessing it will have to be the 220. Does anyone know how well the 220 fits inside this plane with muffler? Cheers, oh and any ideas how fast u would expect it to fly with a 220 3 blader. thanks guys Jarrah, My post #32 in this thread, and others, show pictures of a Saito 220 mounted on this plane with just the valve covers extending outside of the cowl. My pics don't show the stock muffler installed, as I intend to use a Keleo pitts-style, but the H9 instruction manual shows a picture of a 220 with the stock muffler extending downward in the lower rear cowl exhaust area. Hard to tell if the cowl needs any cut-out for that placement, but if so, it would probably be minimal (and hopefully, same for the pitts muffler). Sorry, but I don't know the speed you can expect with a 3-blade on this engine/airplane combo. I'll be breaking in the engine soon (on test stand, inverted) with a MAS Classic 18x8 and eventually will try a 20x8 to see if the (broken in) 220 can handle it. Other Saito engine threads imply that size is at the upper end of what the 220 can swing at a decent max RPM. Bo
_____________________________
The more planes you have in your "hangar," the less likely your wife will notice a new one!
