RE: New Hangar 9 1.50 P-51 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: New Hangar 9 1.50 P-51 Build
Page: <<   < prev  50 51 [52] 53 54 55 56 57 58 59   next >   >>
Login
RE: New Hangar 9 1.50 P-51 Build - 4/3/2008 2:08:49 PM
tsyssa
Status: offline
Me too!
Due to baby/wife/business duties...I have not been able to finish my Frankie yet...Still, I am very thankful for these duties...and Frankie will be in the air soon enough.
I will feel better once the ground is a bit thawed also...just in case.
Very, very, anxious!
Thanks for posting your TX mix and settings Rip!
_____________________________
Best regards, Todd Syssa
Syssa Aircraft Performance (860) 538 - 2937
(in reply to Rip n Bank)
       Post #: 1276
RE: New Hangar 9 1.50 P-51 Build - 4/3/2008 2:52:18 PM
Rip n Bank
Status: offline
quote:
ORIGINAL: tsyssa
Me too!
Tsyssa,
While your mileage (settings) may vary, I'm happy to share what works for me.
BTW, your priorities in life are right on; and when you DO get a chance to attend to the "duty" of taking a break for yourself, Frankie will treat you right, don't worry!
Rip
The more planes you have in your "hangar," the less likely your wife will notice a new one!
(in reply to tsyssa)
       Post #: 1277
RE: New Hangar 9 1.50 P-51 Build - 4/3/2008 3:54:44 PM
C.ops
Status: offline
C.ops, I was going to ask if anyone had put in the Zenoah G38 in the p51 , but the pics from Diablokid answers my question, any info on that installation would be appreciated as I was going to use the G26, but was advised to go to a bigger engine, the G38 doesnt seem much bigger. The pics look great by the way. Going to Toledo Sat.
C.ops
(in reply to captainron)
       Post #: 1278
RE: New Hangar 9 1.50 P-51 Build - 4/4/2008 1:26:45 AM
kahloq
Status: offline
Got my decals for the nose art and plane name in the mail today. Soon, she will be done
(in reply to C.ops)
       Post #: 1279
RE: New Hangar 9 1.50 P-51 Build - 4/4/2008 1:35:18 PM
craigss11
Status: offline
Hi,
I'm sorry I have to ask this,but I've read and reread all the pages and obviously missed it,but has anybody else had trouble with getting the horizontal stabaliser tight against the fuselage?
I've tried pushing the stab.against the fuse. and redrilling and tapping the hole in the aluminum tube and then pressing it the other way and drilling that side and tapping
But still I have play.
I don't need to be able to remove the tail,is there any reason I can't epoxy it in?
(in reply to kahloq)
       Post #: 1280
RE: New Hangar 9 1.50 P-51 Build - 4/4/2008 1:53:14 PM
Rip n Bank
Status: offline
quote:
ORIGINAL: craigss11
Hi,
Craig,
After I tapped in one of the screws into the aluminum tube, I marked the other side of the tube, thru the other stabilizer hole, with the stabilizers both pressed tightly against the fuselage (duh).
But, then, when I drilled and tapped the second mark, I did it about 1/32" further inward than the mark. It took a fair amount of pressure on each stabilizer, when reinserted, to get the screw to thread into this second hole. This resulted in almost no gap at all between the fuselage and the inside ends of the stabilizers. USE BLUE LOCTITE ON THE SCREWS!
As to your second question, I've never once felt the need to remove the stabilizers since installed (they don't interfere with storage or transportation), so I don't see a downside in epoxying them on except for the difficulty of later replacement if damaged.
Rip
(in reply to craigss11)
       Post #: 1281
RE: New Hangar 9 1.50 P-51 Build - 4/4/2008 8:25:23 PM
craigss11
Status: offline
Thanks a lot for your advise,I'll try that
Cheers
       Post #: 1282
RE: New Hangar 9 1.50 P-51 Build - 4/5/2008 12:58:20 AM
kahloq
Status: offline
Although I like Rip's suggestion, I simply epoxied them in place. If there is damage where one side or the other needs complete replacement, its not gonna matter since it'll be pretty badly destroyed...and probably a some of of the rest of the plane as well. So, simply using a file or something to get the epoxy residue off the alum. tube would be needed once the damaged part is pulled off. Sure, alot more work then undoing a screw, but, I dont have a tap screw.
       Post #: 1283
RE: New Hangar 9 1.50 P-51 Build - 4/5/2008 7:31:32 AM
craigss11
Status: offline
quote:
ORIGINAL: kahloq
Thanks for all your advise,I'm going to redrill and tap the tube and epoxy the stabiliser as well,as you guys said,I really don't wish to dismantle it for storage or transporting so it might as well be solid as I can get it to be
Cheers
       Post #: 1284
RE: New Hangar 9 1.50 P-51 Build - 4/5/2008 3:22:53 PM
tsyssa
Status: offline
I think I'm going to epoxy mine as well...if it crashes...I think I will have more to worry about than removing the elevator!!! LOL
I just dont trust a screw holding things together in the method they have. Its only the threading on that aluminum tube!
Normally you tap for length 1.5 times the OD of the thread....this is quite well below that.
If it was designed the way my Aeroworks yak 54 is...that is an excellent way to do it. Two screws under each stab going into the fuse with blind nuts. Very nice setup indeed. May even convert mine to something like that if it is possible.
       Post #: 1285
RE: New Hangar 9 1.50 P-51 Build - 4/6/2008 2:25:19 PM
frisconick
Status: offline
Finally got the maiden in yesterday. Three flights with no mishaps. None all too pretty though. It wanted to climb hard; took 15 clicks of down elevator, but looking at it on the ground, it didn't really deflect the elevator too much. I might have had it a bit up at neutral to start. I think the balance is OK. It needs a little down to fly inverted, but not too much. Tried the flaps on the second landing, but didn't have enough speed up during touchdown. It put a bit of stress on the gear, but everything held up well. The last landing was the best; a bit of a cross wind blew me off the asphault runway onto the grass, but I kept the shiny side up. I leaned out the Saito 220 after the first flight. It's turning about 8700 with the 18x8 MAS. It felt like I could have gone leaner, but I'll wait until a few more flights. Not sure at what point it happened, but the weld on the Keleo exhaust broke between the short header pipe and the muffler. I know I heard of this happening before, but not sure if it was on this thread. Anyone have this prob? What did Kelvin do? I really don't want to be out of commission for 2-3 weeks. I'll call him tomorrow. Other than that, all else is well.
Nick
       Post #: 1286
RE: New Hangar 9 1.50 P-51 Build - 4/6/2008 8:27:13 PM
Tisoy909
Status: offline
Nick,
Go back one page youll see my pics and account of what happened with my Keleo Exhaust.
(in reply to frisconick)
       Post #: 1287
RE: New Hangar 9 1.50 P-51 Build - 4/6/2008 11:25:57 PM
kahloq
Status: offline
I believe Rip N Bank may have also had this issue. So, I guess I should look forward to having mine break too!! Wonderful.
(in reply to Tisoy909)
       Post #: 1288
RE: New Hangar 9 1.50 P-51 Build - 4/6/2008 11:28:27 PM
frisconick
Status: offline
Yep. Just like yours. Broke in the same spot, but I didn't notice a change in exhaust note. Maybe it was broken for all three flights??? Will call Kelvin in the morning.
Nick
       Post #: 1289
RE: New Hangar 9 1.50 P-51 Build - 4/7/2008 12:30:41 AM
Tisoy909
Status: offline
