Rip n Bank
CO, USA Status: offline
quote:
ORIGINAL: kahloq Although I like Rip's suggestion, I simply epoxied them in place. If there is damage where one side or the other needs complete replacement, its not gonna matter since it'll be pretty badly destroyed...and probably a some of of the rest of the plane as well. So, simply using a file or something to get the epoxy residue off the alum. tube would be needed once the damaged part is pulled off. Sure, alot more work then undoing a screw, but, I dont have a tap screw. Sorry, I've been out of town on pleasure and business since last Friday, with no time to access this thread! I'm the first to agree that if you heavily damage a stabilizer when flying the plane, there probably ain't too much forward of that spot worth repairing! However, I do stupid "hangar rash" accidents on occasion, including the walking of a horizontal stabilizer into a door jamb on the way to the garage. 99% of the aerodynamic load on the stabilizer is not translated to the screw tapped into the thin sidewalls of the stabilizer spar, so I don't worry much about that not holding up. Bottom line: in practice, there's probably not much difference between screwing on the stab w/ blue loctite, or epoxying on the stab, instead. Rip
_____________________________
The more planes you have in your "hangar," the less likely your wife will notice a new one!
