Rip n Bank
CO, USA Status: offline
quote:
ORIGINAL: Schweizer K I am in the process of installing my servos in frankie, but cannot come up with a location to install a servo and air valve for the robart retracts I will be using. I have added one servo in front of the rudder servo for the choke, which does not leave me with very much space in front of the other servos. Any suggestions ? Keith Hmmm, where will you locate the air tank? It's appreciably bigger than the servo/valve combo.Regardless, the center servo bay, like you said, is pretty full. If I were replacing my Frankie's mechanicals with a pneumatic system, I'd probably put the lightweight air tank in the rear bay under the pushrods, and put the servo/valve assembly in the forward compartment behind the fuel tank, or as an alternative, integrated into the wing, itself (ie, cutting into the sheeting, and mounting in the top center of the wing that is covered by the fuselage). The latter requires that you have only one quick-connect fitting between the tank and the valve when you attach the wing, versus two if you mount the valve inside the fuselage (assuming air-up/air-down). Rip
_____________________________
The more planes you have in your "hangar," the less likely your wife will notice a new one!
