kahloq
CO, USA Status: offline
quote:
ORIGINAL: Tisoy909 Just curious, i notice you guys are using 16 inch props in and around the 10 pitch, will this really give considerably more speed as im thinking thats gonna cause to over rev the 220. I was breaking in using an APC 18x8 wide prop and the speed is already very fast although i havent tried radar speed checking the speed of the plane at full bore or anything, im thinking of even using the 18x10 or 19x8 wooden Xoar prop, is this going wrong with this 220? thanks. Louis Its not going to over rev in flight if the static rpms read 9000 or lower on the ground. It'll pick up maybe 300-500 rpms due to unloading, but thats gonna be standard with whatever prop. Now...if someone were getting 9500+ Id be worried. AS such, that is why I wouldnt put a 16x8 on mine cuz I know it'd be pretty close to 10K. I also think a 16 inch diameter 2 blade prop is marginal thrust wise as well for a 16+ pound plane. Sure, im running a 16x10, but a 3 blade so its comparable to a 17" 2 blade prop thrust wise. Hopefully it'll be enough. I expect it to take a little more runway to get off the ground then it does Bo's plane with the 18x8. If I could find a 17" diameter 3 blade prop, Id be happy. Anyone with ideas?
