Rip n Bank
CO, USA Status: offline
Captain, I'm amazed you didn't have to reset your needles after you inverted the 100! Mine took alot of adjustment, but now, it runs like a dream. I have a solid, heavy engine stand, so I'll break in the 220 on that. I'm planning to run up to two gallons of 20/20 through it before it's bolted back in the 'Stang for the maiden. Can't wait to hear it's exhaust note! Rush's "Red Barchetta" defines this as "Mechanical Music"... Bo quote:
ORIGINAL: captainron quote:
ORIGINAL: Rip n Bank quote:
ORIGINAL: BankYank It does not matter. Just make sure you have it adjusted right or it will never run right as with all inverted engines. Pat Pat, I agree on the adjustment comment. I took a "well broken in" Saito 100 and installed it (inverted, obviously) in an H9 60 P-51 and spent LOTS of time, and flights, getting the high-speed and idle mixture just right. Could only pull it off with a hotter glow plug, though. Bo RIP N BANK, I broke in a Saito 100 this last summer. Put two tanks through it on a break in stand. I got everything set perfectly. Mounted the engine on my Hanger 9 P-40, put 20 or so flights on it this last summer and never had to touch the needle valves, high or low. I love my Saitos. I only hope this new 220 is as good as my 91's and the 100. I'm definetly going to break the 220 in on a good solid break in stand. Atleast two or three tanks, or 40 minutes as the manual calls for before we go aviateing. Just can't wait to hear this big 220 come to life. DANG, I LOVE THIS HOBBY, CAPTAIN RON.
_____________________________
The more planes you have in your "hangar," the less likely your wife will notice a new one!
