Rip n Bank -> RE: New Hangar 9 1.50 P-51 Build (2/10/2007 6:37:03 PM)
quote:
ORIGINAL: reincarnate You're the man Rip. Hope your legs don't get tired running all of these errands for the crowd. Already own all of the air junk, already bought the dang 791's, just don't want to add another dang battery to already fat bird (lots of scale detail. Gonna post an exact weight of mine later today). Asked Danny @ JR in radio thread, so if you want to follow what he says, check that. Here is why I'm still stalling on this. You can't adjust the travel or end points of gear channel/servo. So if you have your servo set up correctly, it will run to its end point and stop without overdriving. Just thinking out loud, not about to outguess the experts. Like you said, "It's only a $1500 airplane". Now stop messing with my head![:D] How's the exhaust coming? I'm looking forward to seeing it. Keep up the great work. Don't mind the "errands." I'm mostly chasing these things down for my own project, and peace of mind, so it's easy to share what I find along the way. I'm going to be interested in your final weight. In the overall scheme of things, I believe the weight of an extra (4.8 volt) battery (3 oz.) adds very little additional wing loading in a plane that's known to be pretty reasonable in that department. My scale exhaust (now mounted!!; pics coming soon!) weights next to nothing. Fiberglass reinforcing of firewall, wing mount and gear rails: what, an ounce or two? Upsized gas tank (23 oz stock to 27 oz World Models): +1.5 oz more (empty, of course). My heaviest addition so far is the on-board glow system with self-contained battery: 3.5 oz. All in all, my add-on's are just over 1/2 lb. Now, something tells me the Elite Force pilot weights alot (Petter: did you weigh yours before installing?). Still don't know if I'll add one of those, yet, even if I find one. I'm no expert on retract servos, except I know, as you state, they have no adjustment in their end points. The Horizon techie said something like if there is any linkage resistance to the servo reaching it's end point, it'll burn itself out trying to hold end-point using 6 volts (or something to this effect). Using these inputs, I ordered both a 6-volt battery, for the Rx and HiTec 545 servos (they love 6-volt), and a 4.8 volt battery for the 791 retracts (both Sanyo NiMH 2500 mAh) from Batteries America. Gotta go put another Cub Yellow coat on my DB spinner, eat lunch, then I'll take some pics of my scale exhaust and post them... Cheers! Bo
