Jim Messer
Joined: 1/28/2002 From: Sebring, FL, USA Status: offline
As you can see by the previous photos, I have the cowl under construction also. There is a Zenoah GT-80 bolted to the firewall, and the cowl framework is being constructed around it using balsa. When I get it to the point of near finish, I will cover the front section of the fuselage nose just ahead of the landing gear with waxed paper, and then fiberglass the whole cowl so that the cowl joint will be just forward of the landing gear - and not where it now appears to be. When the fiberglassing is done, then I will balance the airplane. If it comes in nose-heavy, then most of the balsa cowl framework will be removed. Should it come in tail-heavy, however, then the cowl will remain as built - keeping the balsa framewok intact. I have a fiberglass arrowshaft in place for the CG, so that the model can be hung from the ceiling to do the balancing. I will post pictures of this process when the time comes. The radio and servos are installed, and this shows in a photo of the cabin with the |
