Sport_Pilot
GA, USA Status: offline
quote:
'plug number' is the actual flight speed of the plane; They test props in a wind tunnel with no plane attached. They also test fans, including propeller fans, for efficiency and they never move a plane. I think your statement is essentially correct, however it may give a slightly differant percentage if calculated that way. The actual equasion is THP/BHP or the theroritical power to move a propellor, over the actual HP. However the theroritical HP will change for a propellor that is static VS one with incoming air, thus the combined equasion with air velocity. If using advance ratio the TAS is devided by the RPM and diameter. But others simply use the differance in incomeing air or TAS VS propblast speed.
_____________________________
“I Saw Elvis at 1000 Feet” John Force
