RE: Props-More Myths Busted
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Props-More Myths Busted
Page: <<   < prev  8 9 10 11 12 13 14 15 [16] 17   next >   >>
Login
RE: Props-More Myths Busted - 8/18/2007 6:53:22 PM
DarZeelon
Status: offline
Hugh,
There is a certain eventual pressure difference, between the air directly behind the prop and directly in front of it...
This is essentially thrust...
We may be oversimplifying it, but any way you look at it, efficiency is essentially the eventual thrust divided by the calculated thrust and the 'plug number' is the actual flight speed of the plane; or if measured in a wind-tunnel, the speed of the air flow inside it...
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to Sport_Pilot)
       Post #: 376
RE: Props-More Myths Busted - 8/19/2007 4:25:28 AM
blw
Status: offline
That is a good way to put it, Dar.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to DarZeelon)
       Post #: 377
RE: Props-More Myths Busted - 8/19/2007 3:20:47 PM
Sport_Pilot
Status: offline
They test props in a wind tunnel with no plane attached. They also test fans, including propeller fans, for efficiency and they never move a plane.
I think your statement is essentially correct, however it may give a slightly differant percentage if calculated that way. The actual equasion is THP/BHP or the theroritical power to move a propellor, over the actual HP. However the theroritical HP will change for a propellor that is static VS one with incoming air, thus the combined equasion with air velocity. If using advance ratio the TAS is devided by the RPM and diameter. But others simply use the differance in incomeing air or TAS VS propblast speed.
(in reply to blw)
       Post #: 378
RE: Props-More Myths Busted - 8/19/2007 5:28:01 PM
jaka
Status: offline
Hi
Lot's of fysic theory here...but down to the nitty gritty...a small 10" fourblade prop isn't going to work as good as correct size two blade one. That's fact...won from experience. Every one that has been around this hobby long enough knows that!
So don't give the guy expectations that isn't going to be fullfilled. A too small 4 blade prop is also looking rediculous on any fighter.
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
       Post #: 379
RE: Props-More Myths Busted - 8/19/2007 9:14:52 PM
RVM
Status: offline
If nothing else, this is 100% true.
quote:
ORIGINAL: jaka
There is no substitution for human competition.
(in reply to jaka)
       Post #: 380
RE: Props-More Myths Busted - 8/20/2007 1:35:00 AM
blw
Status: offline
The APC prop that I gave links to is an 11 inch prop for a .46 sized P-51.
(in reply to RVM)
       Post #: 381
RE: Props-More Myths Busted - 8/20/2007 6:35:00 AM
DarZeelon
Status: offline
Barry,
This is what Tower shows for four-blade APC props.
The 11x6 size states (on the package) it is for .61 two-strokes, however.
The Saito .72 spun it pretty well.
(in reply to blw)
       Post #: 382
RE: Props-More Myths Busted - 8/20/2007 10:30:34 AM
speedster 1919
Status: offline
My mule engine and plane and thrust scale are now fixed. I have more props to test. Now I need to look for a small 4 blade to test on a .45. You wise guys that tout the great efficentcy of 2 blade need to tell full size aircraft manufactures to knock it off, using those bad multiblades. Take the 8 blade counter rotating turbo props. Shame on them--They shouldn't even leave the ground. Jaka where is your big prop test?
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
(in reply to jaka)
       Post #: 383
RE: Props-More Myths Busted - 8/20/2007 12:50:01 PM
gkamysz
Status: offline
Who said the full scale manufacturers are wrong? I don't think a single person has said that full scale is wrong in their prop choice. However most of the do a little better than picking a prop off the hobby shop shelf. Chances are that whatever they choose it will be a better than what 99% of modellers choose. I'm pretty sure I posted a link to Martin Hepperle's analysis of three blade props for F3D several pages back.
Maybe a long time full scale prop manufacturer can shed some light on the topic.
http://www.hartzellprop.com/engineering/engineering_faqs.htm
Greg
(in reply to speedster 1919)
       Post #: 384
RE: Props-More Myths Busted - 8/20/2007 7:03:50 PM
w8ye
Status: offline
Was this interesting prop measuring tool mentioned on here before?
http://www.go-cl.se/propg.html
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to gkamysz)
       Post #: 385
RE: Props-More Myths Busted - 8/20/2007 8:05:38 PM
jaka
Status: offline
Hi!
Speedster.... I know that fullscale props arn't two blade because then those Merlins and Alisons powered Mustangs and P-40 fighters must have very long gear legs and the prop diameter would put very large forces on the blades and hub.
The problem for enginers in those (WW2) days (and today in full scale racing) was/is to have a prop that could absorb the power from the engine and still not be too big in diameter.
That's why you see fullscale Sea Furys and Spitfire Mk 24 using 5 or more blades...and modern turbo-prop airplanes using even more prop blades. But in our model world every one that has been in this hobby long enough knows that for performance ...and speed (like Pylonracing) you got to have a two blade prop.
In Cl speed even one blade carbon props are used.
< Message edited by jaka -- 8/20/2007 8:07:01 PM >
       Post #: 386
RE: Props-More Myths Busted - 8/20/2007 11:19:37 PM
blw
Status: offline
The advantage of a single blade as in CL does not apply to RC or free flight as the P factor forces on the fuselage and vertical fin would cause problems. You don't really see this when on a control line, but you probably would in flight. A propeller with more than 2 blades would produce a smoother effect and dampen gyroscopic precession effects if they were felt in the first place. Vortices from the 'advancing blade' would not be a factor. There would be better vibration control. 3 and 4 bladed props are making a bit of a comeback in RC pattern flight today.
(in reply to jaka)
       Post #: 387
RE: Props-More Myths Busted - 8/20/2007 11:24:21 PM
djlyon
Status: offline
Lotsa single bladed props in free flight and they seem to work on F5D Pylon
I never met an engine I didn't like.
Of the things I've lost I miss my mind the most.
(in reply to blw)
       Post #: 388
RE: Props-More Myths Busted - 8/20/2007 11:34:56 PM
blw
Status: offline
I didn't know that. Interesting.
(in reply to djlyon)
       Post #: 389
RE: Props-More Myths Busted - 8/21/2007 12:58:31 AM
djlyon
