bigben2k
TX, USA Status: offline
Quite a fabulous debate, just finished reading it! I'm building a PBY Catalina, 1:10 scale , and a 3 blade prop is a must: 2 blade isn't even a consideration. The hardest part to understand, for those struggling to follow, is how different props can be best for different applications. The hardest part to explain otherwise, is how a static test is different that a dynamic one, and why it makes a difference. For the first, I'll throw in a car analogy: if you ran your car with small wheels, you'd have great acceleration, for the first little bit, then later as speed increases, just about any other car would overtake you. On the other hand, if you setup your car with unusually large wheels, you'd loose the acceleration, but you'd be able to get to that higher up speed. If you want to run (and win) short races, use small wheels. I figure that the same applies to propellers. As for static versus dynamic, I'll defer to others more knowledgeable than me. Building a Catalina at this scale, I'm ending up with a 14 inch propeller, with 3 blade. This is scale, and I don't care how it runs, sluggish would actually be good! As it turns out though, a Master Airscrew 14x7 3-Blade G/F Nylon Propeller will probably work very nicely with the engines I'll end up with (a couple of either .61 or .90 two stroke, once I've completely ruled out going electric). I'm learning more about propellers in this thread than I could ever pick up any other way.
< Message edited by bigben2k -- 10/21/2007 5:03:04 AM >
