MJD
ON, CANADA Status: offline
quote:
ORIGINAL: RVM Actually, I think what he is saying is that using a lower pitch allows you to use a larger diameter, thus allowing for more thrust. Obviously, there are diminishing returns, but there is a reason large diameter, low pitch props are used, especially for 3d. Now that I can accept if that is what is being said. On a related subject, I scratched my head a bit recently at a comment made by a well known engine reviewer, who said that for maximum static thrust, prop the engine for maximum torque, not maximum HP. "Static" thrust is a misleading term, in that the only static part is the speed of the engine relative to the surface of the earth. The air sure ain't static. To accelerate a larger mass per second of air to the same speed, or the same mass per second to a higher speed per second takes more power, not more torque. So for a particular engine to produce maximum static thrust it needs to run at it's maximum power output AND be coupled to the right prop for the job (ah, there's the rub!). IOW, if he and I were squared off on a test stand with the same .60 engine, pipe/muffler, and fuel, and if prop choices were anything you want - I'd choose running the engine at maximum HP rpm with a large diameter fine pitch prop. But I wouldn't be flying with that same prop unless all I was going to do was hover or fly slowly. I liken the prop situation to a bell curve - there is an optimum air speed for a particular prop/engine combo, and on either side of that you start to lose some pull but it doesn't drop off like a rock. But if you go too fine on the pitch, the peak of that curve is sitting at or close to zereo airspeed, so you lose the "left" side of the curve and therefore your total flight speed regime is narrowed. But yeah, for 3D flying I guess that is pretty much where you want to be, or close to it depending on Vne for your airframe. MJD
