pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
I re-hashed the numbers to grams and comma separated values, so they can be imported in spreedsheets. The first row is titles PROP ,idle RPM ,about 8500 RPM, thrust gr,WOT RPM, thrust-gr 9x6 three blade plastic ZINGER ,3300,8480,539,13800,1931 9x7 three blade plastic MAS ,3120,8480,767,12300,1704 10x4 MAS /G ,3660,8460,511,14970,1761 10x4 APC ,3200,8550,539,12500,1676 10x4 wood TOP FLITE ,3460,8550,767,12010,1392 10x6 MAS scimitar profile ,3600,8480,852,14160,2215 10x6 MAS /GF/3 wide ,2970,8580,965,11970,1875 10x6 APC ,3270,8490,965,11940,1875 10x6 ZINGER wood ,3120,8520,994,11280,1789 10x8 MAS /GF/3 wide ,3270,8490,1193,10950,1875 10x8 ZINGER wood ,3330,8550,1164,10980,1789 10x8 APC ,3000,8580,1051,11050,1562 10x8 MAS /G ,3240,8490,937,11400,1477 It is interesting to see how there are differences in thrust with different pitch (Thrust-HP says no!) It also is interesting to note that so-called stalled props still achieve higher thrust with rpm increase. Something to ponder what stalled means when talking props. In my opinion, props dont realy stall like a wing when more pitch is applied, unless the pitch becomes excessive (like more than 1D as in a 10x10 prop) From the data it becomes clear why MA props are popular with the RCcombat crowd. They provide excellent thrust, at reduced engine loads.
< Message edited by pe reivers -- 12/17/2006 7:32:52 PM >
_____________________________
Pe, MVVS, MTW, Mejzlik. www.mvvs.nl There is sanctuary in analisys.
